Multichord
I think that there was already such issue but I can’t figure if there was solving.
If I’m trying to use Multichord midi-fx on instrument layer (no matter what engine) all multipled notes are sustained forever after releasing the key.
We didn’t find the cause of that issue. I couldn’t reproduce and the reporter felt the issue want worth pursuing.
Please raise a GitHub ticket describing the config and workflow to reproduce.
Was there ever ticket for this? I tried multichord and it had the ability to do different voicings which is missing from basic midi chord utility. I got it to work through 5pin midi but 2 of my usb devices have notes hanging on as if they would never get midi noteoffs through. One is a generic usb midi and other one is pi pico based custom midi keyoard.
There were some updates to this suite of plugins recently. I am not aware of an issue with the most recent version. Ensure you are up to date with zynthian updates. If you experience problems then please use the, Report Issue " button in webconf to create a ticket.
Okay, thanks for the info, i think i have the latest stable. I tested it a bit more and raised ticket: Issue: Note hang using multichord with usb controllers · Issue #1375 · zynthian/zynthian-issue-tracking · GitHub
Thanks! I have moved the GitHub ticket to the upstream repo as ticket #10. I think it is resolved upstream. (Bad handling of low velocity which will affect MIDI controllers that send note-on, zero velocity for note-off.) Please let me know whether you can test this.
Cheers!
Thanks @riban! With help from copilot i was able to ssh and compile the lv2 to zynthian. All my controllers work as expected now.
Edit: I’m trying hard to record some offerings but all wav files somehow come out as 0 bytes and I’ve got no idea why so it has to wait.
