Hi y’all!
I just finished assembling the Zynthian, it seems that I would need to correct the ‘control button issue’ which don’t seem to work. I will link it to the network later on.
I also experience what looks like a lack of power from the usb supply, which is a bit disappointing but nothing that can’t be fixed.
What do you mean by the control button issue? Do you mean the separate I/O connections for switches?
USB power supplies are the cause of most of the problems we’ve probably seen.
I like the matching appearance to the the shelf!
It’s a good idea to connect to the Internet or your LAN, simply because you can easily update to the most recent software version easily.
Obviously you can do this over wifi as well, but for any serious network use, it’s probably a good idea to consider Wired Ethernet.
Well, I read that the 4 controllers shouldn’t work correctly at first :
“If you are using the Aruk RC-3 SD image (which you should), you will notice that the controllers are not working at all. This SD image is pre-configured for working with the kit v2, so you need to configure the software for working with the kit v3.”
So this is the part I must look after first.
So I managed to change the kit choice using the Explorer (V3 ); but after the reboot the controllers still don’t work.
I also have two small red warning signs blinking, a little red triangle and a little red lighting sign.
Can anyone help me to get these issues cleared out?
I’m using a 5v/2,1A PS. I got rid of the triangle, only the red flash sign is left…does this indicate poor power supply ?
And may this lead to a malfonction of the encoders?
I tried a software update which starts with the word ‘fatal’…that doesn’t look good does it?
Anyway, bad power supply can provoke all strange issues you can imagine.
Your priority should be getting a decent power supply … or a decent cable!! Seriously, the cable is as important (or more!!) as the power supply!
Thanks to you guys for coming to my rescue !
I ordered (after trying several usb power supplies that I had laying around) a 3 amp PS designed for Raspberry, so that should solve the power issue.
I will now replace the RC-3 OS image by the one you linked me José, I will of course keep you informed.
Anyway, no matter what happens next (maybe there will be some other surprises) I really want to thank the community here for being so friendly and helpful. When I saw this morning that José answered me after midnight…wow man what can I say?
Besides that I really enjoyed the first part, the construction procedure is really good and I had fun assembling the kit. Besides the final construction is real sturdy, ergonomic and attractive to the eye (especially in my ‘real oak faceplate’ ofcourse !
Greetings to you all!
The Zynthian is working but…there are quite a lot of uninvited noises playing around (clicking, popping, the usual suspects)
now I suppose they’re probably linked to the little ‘red flash’ icon, indicating a power issue (?).
I ordered a 3 Ampère PS this morning so let’s hope this wille solve that problem…anyone had the same experience?
When the power supply is insufficient the under power indication lights (occasionally) and the CPU is throttled which results in less processing power available. This may be caused by the PSU being unable to deliver required current or the cable having too high impedance, resulting in voltage drop across the cable.
xrun indicates that there is insufficient time to process a block of audio. This may be caused by insufficient CPU which may be caused by insufficient PSU current.
When an xrun occurs there will be a discontinuity in the audio signal which results in an audible click. xrun may be buffer underrun (insufficient audio data reaching the DAC) which would put hole (short silence) in the output or it may be a buffer overrun (too much data reaching DAC) which would put a discontinuity (sudden jump in sample level). The former (underrun) is most prevalent.
A weak PSU or poor quality cable is probably the most common cause if issues with Zynthian and sounds like the most likely candidate for your sound issues.
Once again thanks for the very complete and explicit reply; I will normally receive the correct usb charger around Wednesday so let’s wait and see.
So far i’m amazed by the huge number of ‘sounds’ , all very usable and great.
Yes!! I found the good old WORKING USB power supply in the back of the good old drawer!!
So it’s only noted for 2,1A, still the Zynthian works correctly and fast, it’s absolutely wondeful!
I’m very happy about my choice for this project, the sound really is great (Out to Roland Edirol UA-5 sound card and into my headset), lots of headroom, no boxy or metallic (cheap) sounds, very mellow and deep.
Now if you will all excuse me I have to get back to playing with my Zynthian
