#!/bin/bash
cd $ZYNTHIAN_PLUGINS_SRC_DIR
git clone https://github.com/BramGiesen/arpeggiator_LV2.git
cd arpeggiator_LV2
sed -i 's#^PREFIX := /usr#PREFIX := #' Makefile
sed -i 's#^LIBDIR := $(PREFIX)/lib#LIBDIR := #' Makefile
sed -i "s#^DESTDIR :=#DESTDIR := $ZYNTHIAN_PLUGINS_DIR#" Makefile
make -j3
make install
cd ..
I just found this too and installed it from source. I have had a play and it works really quite well. It can synchronise to MIDI clock and hence zynseq which it does very well. With the recently added MIDI FX it can be inserted in a layer - wow this is great. The only issue I have found so far is that it seems to only output to channel 1. (There is something odd about multiple Fluidsynth layers. MIDI channels work fine under normal configuration.)
Please, pretty please add this to the base build.
Proof it works with step sequencer, here is a drum track played form zynpad and some FluidR3 GM/Yamaha Grand Piano triggered from bg-arpegiator.
And now it isn’t syncing correctly… I have s inking feeling!!! When the fun stops, stop!
Actually - there are issues. It seems to jitter a lot around the clock and can be challenging to synch. More investigation required…
Dear @riban, it’s on the base build from a few weeks ago …
The lastest Buster RC-2 includes this plugin and the update system also will install it on older images.
In fact, i already sent some audio demo using it …
