New PANIC feature: All notes/sounds Off
Hi @Zynthianers!
I’ve added 2 new options to the layer list:
  • All Notes Off: PANIC! => It sends CC123 to all MIDI channels
  • All Sounds Off: PANIC!!! => It sends CC120 to all MIDI channels
I’m not sure of conserving both options, but i prefer to get some feedback from the community before taking a decision.
Both options can be accessed using the Master Channel: if you send CC120 or CC123 to the Master MIDI channel, you should get the same effect :wink:
it’s difficult to choose… all sounds off means they are muted or really interrupted? what happens to sounds loaded in memory (such as samples)?
I am more familiar with notes… and in cases of overflow or too much cpu, is for sure a good workaround to free up zynhtian.
FYI:
  • All Notes Off => It releases the notes in the same way as a note-off. The sound is not cut.
  • All Sounds Off => It stop the sounds abruptly, without release or decay.
This is what the MIDI specification says. The real behaviour depends on the engine implementation.
I’ve added 2 new “switch#0” actions bond to the new PANIC functions:
  • short click: All Notes Off
  • bold click: All Sounds Off
These actions are contextual to the “Layer” screen (you have to be in the layer screen!). In such a way, from the control screen you can trigger the actions quickly by clicking twice the switch#0 (layer).
After the action, you are back to the control screen :wink:
Rregards,
FYI:
“switch#0” is named “CTRL-1” in the documentation:
It’s the top-left switch/controller, labeled as “layer” in the official cases :wink:
And now try to boot zynthian and as first action press CTRL-1
game over :slightly_smiling_face:
(empty layer list)
Ups!! :flushed:
Try now, it should be solved.
Thanks! :ok_hand:
