Cannot connect to MOD-UI via http://zynthian.local:8888/
“connection was refused”
Setup: Ethernet connection via Router, Web-config works, MOD-UI in chani 1
Open an issue, please. MOD-UI is probably broken in bookworm.
oh, how to open an issue?
I fixed the pic I sent before.
I am connecting point to point with an ethernet cable.
“Please, connect to the local network…”
I try but I do not know how to reach it: now I know the MAC address and the IP address in my network
Connect your zynthian to the router with the Ethernet cable. Then try to access webconf using the zynthian.local name.
21 posts were split to a new topic: 500 error on Webconf
I’ve just moved this 500 discussion to a new thread to maintain the flow on oram 64 bit on this thread.
If you update then you will find a menu option in webconf HELP menu that opens a ticket with your system configuration already populated. This makes it easier to report issues in a consistent manner.
I reinstalled, updated, and chose the configuration working with stable 2401:
on boot Zynthian LCD gives ERROR message on loading page
Webconf works properly
It’s the expected behaviour. Zynthian can’t auto detect your custom hardware. It only auto detects official kits. You have to configure your hardware from webconf.
Thanks. I solved as you suggested using custom display
Hi @Joe !
I’ve pushed a fix that allows moving across categories using “horizontal drag” with touch or mouse.
It’s not perfect and i hope to improve things still more in the next days,
Earlier today I tried doing a Software Update on Oram 2403 on V5 which I’ve been running for a while and have updated a few times previously. It hung after outputting the message:
Building wheel for pycrypto (setup.py): started
and after that I rebooted and Zynthian came up OK but the Webconf menu items do not respond at all.
I’m planning to start over with a fresh download unless advise otherwise.
Here are the messages from the Software Update:
Updating zynthian-sys (oram)...
Updated 0 paths from the index
From https://github.com/zynthian/zynthian-sys
28ecc46..609b7e7 oram -> origin/oram
cfbc260..3a44519 chainman_bookworm -> origin/chainman_bookworm
* [new branch] feature/jamulus -> origin/feature/jamulus
7a69951..8331c83 testing -> origin/testing
Updating 28ecc46..609b7e7
Fast-forward
config/zynthian_envars_V5.sh | 2 +-
etc/dnsmasq.conf | 5 -
etc/systemd/mod-ui.service | 14 +-
sbin/mod-ui.sh | 26 +-
.../recipes.update.bookworm/00_install_packages.sh | 27 ++
scripts/recipes.update/update_modui.sh | 35 +-
scripts/recipes/install_mod-ui.sh | 35 +-
scripts/recipes/install_noVNC.sh | 5 +
scripts/setup_system_raspioslite_64bit_bookworm.sh | 25 +-
scripts/update_zynthian_sys.sh | 74 +--
scripts/zynthian_envars.sh | 503 +++++++++++++++++++--
11 files changed, 555 insertions(+), 196 deletions(-)
delete mode 100644 etc/dnsmasq.conf
Updating System configuration...
BOOT LOG DISABLED
OVERCLOCKING => Maximum
RBPI AUDIO ENABLED
OTG ENABLED
SOUNDCARD CONFIG => dtoverlay=hifiberry-dacplusadcpro\nforce_eeprom_read=0
DISPLAY CONFIG => display_lcd_rotate=2\ndtoverlay=rpi-ft5406,touchscreen-inverted-x=1,touchscreen-inverted-y=1\n
CUSTOM CONFIG => dtoverlay=i2c-rtc,rv3028\n
Configuring X11 inverted display ...
SOUNDCARD_MIXER is OK
Executing custom update recipes...
Executing /zynthian/zynthian-sys/scripts/recipes.update.bookworm/00_install_packages.sh ...
CURRENT PATCH LEVEL: 20240228.1
APPLYING PATCH 20240305.1 ...
APPLYING PATCH 20240308.1 ...
Reading package lists...
Building dependency tree...
Reading state information...
The following packages will be REMOVED:
zynaddsubfx zynaddsubfx-data
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 93.5 MB disk space will be freed.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 176387 files and directories currently installed.)
Removing zynaddsubfx (5:3.0.5-1kxstudio7) ...
Removing zynaddsubfx-data (5:3.0.5-1kxstudio7) ...
Processing triggers for man-db (2.11.2-2) ...
The following additional packages will be installed:
zynaddsubfx-data
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 4,079 kB of archives.
After this operation, 12.5 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main arm64 zynaddsubfx-data all 3.0.6-5 [3,121 kB]
Get:2 http://deb.debian.org/debian bookworm/main arm64 zynaddsubfx arm64 3.0.6-5 [958 kB]
Fetched 4,079 kB in 1s (3,298 kB/s)
Selecting previously unselected package zynaddsubfx-data.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 174817 files and directories currently installed.)
Preparing to unpack .../zynaddsubfx-data_3.0.6-5_all.deb ...
Unpacking zynaddsubfx-data (3.0.6-5) ...
Selecting previously unselected package zynaddsubfx.
Preparing to unpack .../zynaddsubfx_3.0.6-5_arm64.deb ...
Unpacking zynaddsubfx (3.0.6-5) ...
Setting up zynaddsubfx-data (3.0.6-5) ...
Setting up zynaddsubfx (3.0.6-5) ...
zynaddsubfx set on hold.
APPLYING PATCH 20240308.2 ...
Cloning into 'mod-ui'...
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting pycrypto
Cloning https://github.com/dlitz/pycrypto.git (to revision master) to /tmp/pip-install-dqng4l84/pycrypto_c4f1adf803774bbc9c418c164c85f313
Running command git clone --filter=blob:none --quiet https://github.com/dlitz/pycrypto.git /tmp/pip-install-dqng4l84/pycrypto_c4f1adf803774bbc9c418c164c85f313
Resolved https://github.com/dlitz/pycrypto.git to commit 65b43bd4ffe2a48bdedae986b1a291f5a2cc7df7
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Requirement already satisfied: Pillow>=8.2.0 in /usr/lib/python3/dist-packages (from -r requirements.txt (line 1)) (9.4.0)
Collecting pyserial==3.0
Downloading https://www.piwheels.org/simple/pyserial/pyserial-3.0-py3-none-any.whl (87 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 87.6/87.6 kB 443.4 kB/s eta 0:00:00
Collecting tornado==4.3
Downloading tornado-4.3.tar.gz (450 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 450.9/450.9 kB 2.2 MB/s eta 0:00:00
Collecting aggdraw==1.3.11
Using cached aggdraw-1.3.11-cp311-cp311-linux_aarch64.whl
Building wheels for collected packages: tornado, pycrypto
Building wheel for tornado (setup.py): started
Building wheel for tornado (setup.py): finished with status 'done'
Created wheel for tornado: filename=tornado-4.3-cp311-cp311-linux_aarch64.whl size=399638 sha256=4162afde921f1eaa235afddf70dbbee40675c6836e380ee8475292ebc06feb94
Stored in directory: /root/.cache/pip/wheels/f5/3e/96/9a93522329d2a6a1719c92b3ae2dd305cdb3895bf33d84fd18
I tried the new oram bookworm build on an original V4 kit - works nicely after updating via webconf. Is there any chance to have kind of sending the signal to different audio layers but with a fader control before sending? I would like to send i.e. 20% to delay audio layer and 80% to reverb etc.
Another audio producing layer could use the same FX layers with it’s own amounts (i.e. 50% and 10%).
I didn’t get it until now if it’s already be possible. If not I would like to suggest this as an option for every layer producing audio.
Post and Pre fading does not help as far as I understand it. The audio signal is always sent to all choosen audio output layers.
After the update I can no longer create a chain with Zynaddsubfx. The error message on the display reads: Error CUIA Zynswitch (3,‘S’)
Hi @spurkopf !
Could you tell more details, please? All the details, thanks ![]()
Hi @tunagenes !
Did you solve the issue? It seems like something went wrong during the update and you should try to update again.
You could try this command before the update:
echo “20240308.1” > “$ZYNTHIAN_CONFIG_DIR/patchlevel.txt”
Yes, I wrote the Oram 2403 image to a fresh SD card and then updated with no problems, Thank you.
Currently this is not possible. We simply pass the audio through the mixer and can send its post-fader feed to any output or chain. What you suggest sounds like effect sends. This would require different mix levels for each send which doesn’t scale very well. I have considered this because it provides some other useful features / workflows but haven’t had an opportunity to consider what can be done.
One solution against scaling issues could be to have only two or four dedicated send channels for audio FX which are, like the main channel, special channels with their own FX chains. The advantage would be to have common controls for the FXs. And feels more like regular mixing console.
Why doesn’t it scale very well? It’d be the pre-fader signal - with another 0%-100% gain controller - to one of the effect chains instead of the channels mixer fader. There could be some kind of special control screen for these sends or integrated into the normal control screen.
Ok, I’m using zynthian together with a modular ES-9 as audio source/sink (14 in/ 8 out), adding synths of zynthian to the audio mix, and applying effects to the audio chains.
Perhaps I’m totally wrong… but after playing a little bit around with the pre and post fader effects of a chain, I have the strong feeling that pre- and post-faders like in the actual implementation are more or less the same, aren’t they? Where is the advantage of having them separated?
Please, developers, don’t feel offended - it’s just my 2cents.
Yes of course, sorry I thought the error message had more information content.
This is my testing Synth - a pimped Zynthian V2:
Starting with a fresh Installation of 2024-03-01-zynthianos-bookworm-aarch64-oram-2403
after update, only the update button in Zynthians admin page is gone:
At this moment it is still possible to add a Zynaddsubfx synth chain. But this is the third installation where I try this. I still have to search further to find out when the error occurs.
