New testing image Bookworm Oram 64bits
Hi @spurkopf !
Please, note that the update entry is not shown in the admin menu if no updates are available (aka you are updated to the last). When new updates are available, the green heart is replaced by the green recycle symbol and the update entry is shown.
Great innovation, good to know!
Because there has to be a calculation on each chain for each send. Like I said, I’ve not given it too much consideration yet but will do. 4 sends may be sufficient… untill someone asks for 5!!! :wink:
Sooperlooper is not starting on my zynthian v5.
error: cuia Zynswitch (27, ‘s’)
What version of zynthian software? Is it updated? More info please.
https://os.zynthian.org/test/2024-03-01-zynthianos-bookworm-aarch64-oram-2403.zip
this is what I downloaded. If there is a newer version I would like to know.
Did you run an update from webconf or the admin menu?
update button was not responding
ow, now it is. updated to the latest version.
When I add sooperlooper to any chain it gives this error message : cuia Zynswitch (27, ‘s’)
afterwards the system is stuck in the ‘add plugin’ menu.
Sorry, I am away for a couple of days. Maybe @jofemodo can take a look.
Sooporlooper was missed in oram and it should be installed by a recent update. If it failed, you could try to fix it with this command:
apt -y install sooperlooper
But better to find out why update didn’t work.
What version of each repo? You can get this from the webconf dashboard.
[Edit] Also it is worth rebooting adhere an update if stuff isn’t working. I’m theory that should happen automatically if required but there is always the chance we missed it.
This is what I got back:
Failed to fetch http://deb.debian.org/debian/pool/main/w/wxwidgets3.2/libwxba
se3.2-1_3.2.2%2bdfsg-2_arm64.deb Temporary failure resolving ‘deb.debian.org’
E: Failed to fetch http://deb.debian.org/debian/pool/main/w/wxwidgets3.2/libwxgt
k3.2-1_3.2.2%2bdfsg-2_arm64.deb Temporary failure resolving ‘deb.debian.org’
E: Failed to fetch http://deb.debian.org/debian/pool/main/s/sooperlooper/sooperl
ooper_1.7.8%7edfsg0-2%2bb2_arm64.deb Temporary failure resolving ‘deb.debian.or
g’
Is the Zynthian connected to the Internet?
ah, no. It’s connected to the RCport of my laptop.
Connect it to the internet then do an update.
ok, thanks!
In addition to that:
I still had an SD with an Oram Os card with which the error occurred:
After a further update, it no longer occurred and could not be reproduced until now. :+1:
Hello. I’m still trying to make it work on Pi5. Connected it first to internet, than to the PC and again to the router directly, but still nothing. I got this error message “Error Exit:1”. What I’m doing wrong? :melting_face:
