New testing image Bookworm Oram 64bits
Fortunately I found a way to record:
Goto USB memory drive
cd /media/root/ZynthianRec/
jack_capture
GREAT that wil work for now.
PS I noticed that when using modep/patchbox/pistomp (accesible by MOD-UI on the web page, that you have to switch the ‘CAPTURE IN’ on the ZYNTHIAN OFF. Otherwise the audio comes from the card AND via modep processing)
I update ORAM after 1 month of inactivity.
How many changes !! Bravi.
My disappoint is that all sf2 are still not sorted i alphabetical order so for my use is a mess. When could you fix it?
(and touch screen om my V4 is still not working)
The touch issue is solved here:
They are now! Please update. I have only sorted the sf2 banks, not the presets. I think we need to consider what order we sort presets.
Shouldn’t this be fixed in zynthian update process?
Hello Lanfranco, I also cannot use the encoders exactly like you. There must be something to correct in the software since it’s in beta. Let’s give it time; I’m sure they will resolve it.
Many thanks @mnovaro
That reminds me, is there a way to retroactively record something?
e.g. have a recorder with a circular buffer a few minutes long which constantly records.
When the recorder receives a trigger, it dumps the contents of the buffer to disk and keeps recording to disk until a period of silence.
This would let you play around and when you play something good you can record it after the fact without having to record everything. In addition to that, it would mean that every recording has something meaningful in it at a known offset.
I’ve seen a tool called Braindump that can do that for MIDI but not one for audio.
Good evening, I can’t scroll through the engine categories “synt, piano, acoustic, etc” in Oram as the trimmers don’t work. Is there an alternative way to scroll through them without attaching a keyboard to the USB?
Yes, on my Raspi 400 I using keyboard arrows. Except for the Rpi 400, my Zynthian only has an HDMI USB 7" LCD panel and a Behringer 404HD
EDIT: and you can set it by Key_Bindings
We want to implement this for audio and MIDI but have not done so yet.
Then I think I’ll have to wait until the trimmer problem is solved. Thanks for the reply :slight_smile:
after update sort works
but touch screen does not
No! Currently you have to manually fix it as described by @jofemodo but I would like to see the fix added to the update mechanism.
Sorry I have not read yet about the manual fix
It is possible to swipe left and right through instrument categories using the touchscreen (or with Oram’s much improved VNC access)
I look forward to it, thanks :smiley:
Are tooltips something that are on the cards? I mean, something similar to the chain selection screen in the UI that shows info about what synth/effect currently selected. It could be very useful to put that in the options pages, especially the midi settings to help describe what the option actually does.
Strange behaviour of the touchscreen:
Recently (latest oram) I have a strange behaviour of the touchscreen:
If want to shut down with the button [YES] (bottom right), nothing happens, but when I touch in the upper left corner it works. So the touch is somehow “centrepointed mirror”. Same behaviour if I want to name [Save Preset] with the displayed keyboard, bottom left gives letter top right.
How can I correct this?
I did a ORAM fresh installation and touch now works, thank you Jofemodo and have a good Sunday
UPDATE: after update touch screen stopped working
zyncoder: oram (c575089)
zynthian-ui: oram (4daa3b2)
zynthian-sys: oram (99700c2)
zynthian-data: oram (97355e2)
zynthian-webconf: oram (3f1dae4)
