it looks like a clone yes, I just ordered it, few days to come ,
Please, it would be a lot better if you use the last image:
There is no “gorgonilla version” (lite), so you will need a 16GB SD card.
i just sent you the answer
ok so my hifiberry dac came and my tft
its a joy-it 3.2" touchscreen tft
tried pluging the tft in and all I get is a white screen, the same white screen as if nothing is installed on the raspberry
I plugged my hdmi monitor in at the same time and I get the loading text message screen thing, nothing else
Search for waveshare32 in this forum. You need a special wiring.
is it a different wiring or should I edit the config file
I search this
#NO_ZYNTHIAN_UPDATE
For more options and information see
http://www.raspberrypi.org/documentation/configuration/config-txt.md
Some settings may impact device functionality. See link above for details
Tell bootloader to use initram image
#initramfs initrd.img-4.1.13-v7+
Load RT Kernel for RBPI2
#kernel=kernel7-rt.img
uncomment if you get no picture on HDMI for a default “safe” mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display’s size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
Disable Splash Screen
disable_splash=1
Disables dynamic frequency clocking
force_turbo=1
Uncomment to overclock the arm. 700 MHz is the default.
[pi2]
arm_freq=900
core_freq=250
sdram_freq=450
over_voltage=2
[all]
Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
Additional overlays and parameters are documented /boot/overlays/README
Disable Blutooth Support for HifiBerry compatibility with RBPi 3
Swap back the ttyAMA0 to GPIO
[pi3]
dtoverlay=pi3-disable-bt
dtoverlay=pi3-miniuart-bt
[all]
Enable MMAP support (Jackd, etc.)
dtoverlay=i2s-mmap
Audio Device Driver:
#dtoverlay=hifiberry-amp
#dtoverlay=hifiberry-dac
dtoverlay=hifiberry-dacplus
#dtoverlay=hifiberry-digi
#dtoverlay=iqaudio-dac
#dtoverlay=iqaudio-dacplus
#dtoverlay=audioinjector-wm8731-audio
#AUDIO_DEVICE_DTOVERLAY
PiTFT Config
#dtoverlay=pitft28-capacitive,rotate=90,speed=32000000,fps=20
#dtoverlay=pitft28-resistive,rotate=90,speed=32000000,fps=20
dtoverlay=waveshare32b:rotate=90,swapxy=1
Adjust Serial Port Clock to allow MIDI baudrate 31250
[pi2]
init_uart_clock=2441000
init_uart_baud=38400
dtparam=uart0_clkrate=3000000
[pi3]
init_uart_clock=39062500
dtparam=uart0_clkrate=48000000
[all]
No, there is a thread in this forum which tells you what you have to do. I don’t have time to search it right now.
I don’t understand the wiring thing you mean, the tft I have is made for the raspberry pi
it should be plug and play out the box
ive installed the tft on the top of the raspberry and I wanted to test it, to see if I get anything other then the Linux/debian/rasbian loading screen that I get on the hdmi monitor I have
I will check a bit more
well well well
I got webconf working and choise waveshare 32b… screen works, im happy guys
Yes guys it’s working on the screen
I get the zynthian start screen but error
I’ll work more on this tomorrow when my eyes are not ruined
Time to solder the wires and add the dac
Thanks guys
is there anyway I can use my touchscreen on the waveshape tft
and the 3 buttons there on the lcd
OK small step but I’m getting there
My waveshaper 3.2 clone works but I get error
I tried the USB sound card and get error
I tried hifiberry with my hdmi monitor… Get error
I’ve not it any wiring… I’ve got it on custom and everything I blanked out so it does the use any wiring I suppose…
The hdmi got pasted the error screen when I had the hifiberry in… But then again I could not control it… Is there a mouse option or keyboard option
Webconf is working
You should use “dummies” wiring
What model of HifiBerry are you using?
No, he has to use the wiring I described in the link. (PICTURE!)
And this means the webconf setting and the actual physical wiring
hifiberry dac+ HW 2.6
ok ill have to find some encoders and wire them up
thanks guys,starting but slowly getting happier and happier
While not having encoders, any wiring is needed and “Dummies” option should be used.
Of course, when @christianforshaw connect the encoders, the wiring described in the link is the way to go
good afternoon ! I installed the image gorgona_edge only with rp3 and hdmi started normal plus the mause does not appreciate why?
problem solved (I’ve updated), now I’m not going into ui mode
