weird with my mopho synthesizer the notes are still hanging. I will try to install a install the new image freshly, maybe it will work then
Iāve finished building the zynthian kit yesterday, and Iām also experiencing hanging notes with a Yamaha keyboard (via MIDI).
However, I could test the device only shortly and have to check if this happens with all synth engines, or other keyboards.
could your changes rgd the following be the cause?
No. I donāt think so ⦠there are still some problems with SysEx MIDI messages, so perhaps this Yamaha Keyboard is sending some kind of SysEx ⦠could you, @ukitel, verify this?
Iām very unexperienced, so Iām not really sure how to do it.
If Iāve understood well, I would have to read the MIDI output from the Yamaha keyboard and check for SysEx messages: starting with 11110000 and ending with 11110111. Am I right?
I have no way to connect a MIDI port to my computer at the moment, but I could hack something with an arduino and read it from there.
Any simpler way of doing this, through Zynthian interface?
A MIDI record mode similar to the Audio record option might be beneficial.
I created a task:
I was hoping that we could display incoming Midi messages, mainly as an aid for connecting the cables in a setup. But it might be useful to debug these missed notes also.
Prior art!
Excellent!
Consensus!
Itās on the way ⦠
This problem still seems to exist. Iām using a Yamaha Motif ES. I have to set (on the Motif) Utility - Midi - Sync - ClockOut to Off. Otherwise I get hanging notes all the time.
It can be seen at the Midi In led on the Zynthian: when midi clock is enabled, the led becomes dim green (very fast flashing).
I think I have the latest software, I did an upgrade this week:
zyncoder: master (68503c9)
zynthian-ui: master (8fecb5c)
zynthian-sys: master (1f0fd08)
zynthian-data: master (ba07bbc)
zynthian-webconf: master (752430a)
Could you possibly record the MIDI out ?!?!?!?!?!
OK! I will try to solve it when i come back to my lab in Barcelona. I donāt have a āMIDI-clock generatorā ⦠unless ⦠@wyleu do you know if MIDI clock messages are forwarded by QMidiNet?
Kind Regards,
QmidiNet seems to pass clock messages according to sequencer64 playing via Qmidinet to a zynth with an aseqdump at the zynth end.
Could you verify if this clock messages causes some problem (missing note-offs or similar) with some engine?
