Hello José,
Here is my modified image (sry it has autoexpanded to 16Gb and I don’t really know how to reshrink it) I hope you have a large enough SD
Also about your question on pressing enter I am NOT sure this works because I don’t understand your problem sry about that.
What I can do is click any of the synths or mod application in the center panel and enter the instrument and then go down in selecting bank or else or slide the side controllers to change the values and that does work for me.
I never “needed” to click to the side controllers to do what I wanted but I mostly played with dexed and mod so I am not sure about the rest.
Anyway tell me what’s your experience with the image attached or if you could share a short 10 secs video of what doesn’t work so I can see if I have the same…
I received my audio injector and a 7’’ + rasp + iqaudio combined case from max2play.
It’s pretty good CNC machined and fits and protects the quite fragile 7’’ screen perfectly.
There is even an extra panel which was meant for another card which I will redrill to match with the audioinjector connectors.
