flashed a new SD,
updated it
set up the SW for my HW (5" touch screen, NXEZ audio card)
loaded all my SF2
played
switch off the power
The day after I switch on and system does not boot:
green led on Raspberry
screen off,
system does not respond to zynthian.local
nothing happens as if there is not OS in the SD
Green led with no blinking in the RPi?
I doesn’t look like a system problem. It looks more like a hardware issue. Defective SD or dirty contacts, bad power, etc.
I tought the same the first time it happened to me. When it happened first time I changed the SD switching on the HW with a SD card where I installed UBUNTU: no issues.
Later I reflashed ORAM May22 and used half day without issues.
Of course! A cooler is almost mandatory with Pi5. Default Zynthian configuration disables dynamic CPU freq and run at maximum freq all the time, except when sleeped.
But it should boot at less …
I mean the Zynthian enters power save mode after some time without activity. Display is turned off, CPU frequency is reduced, LEDs are lighted off, etc.
Hey there,
After several attempts (and re-downloads) to get the image going on various SD cards, I keep hitting the same brick wall. My Pi5 throws a tantrum, goes completely kaput, and I end up having to do the Pi5 EEPROM recovery to bring it back to life. Any idea what’s going wrong here? The same thing. Three long flashes and one short. After the recovery, I can boot all other sd cards, but not this one.
So it is not contact problem, it is EEPROM failure, every time.
For me it’s still not working. I tried a lot of times, every time I put the new Oram SD card it block after the firs message on the screen so I must to do the eeprom reset. What am I doing wrong? :((
I couldn’t say. I tested with several Pi5 boards here and they all work fine.
Do you have a heatsink in your board? Note that zynthian disables CPU frequency scaling so it could get hot very quickly without a heatsink.
Sure, have a normal heatsink and everything. It cannot overheat, because it happens in 2sec, so when the first message arrives it stucks. Thank you, patience is our biggest friend. :-))
