Oram 2502 Release Candidate
Hi
Today we merged the testing branch (vangelis) into the staging branch (oram) to facilitate testing of the next stable release which is scheduled for approximately two weeks from now. We invite the community to help with testing this version before it is released as the stable version. Your assistance improves the quality for everyone, reducing risk of unexpected bahaviour of the stable release. It is advised that you keep your production system separate from your testing system, e.g. have separate hardware or SD card but you each know your own adversity to risk.
If you have been following the forum you may be aware of several of the resolved issues and enhancements. I don’t think it particularly advantageous to list them here - we can do that at the time of stable release.
If you are using the stable release then this will not impact you unless you chose to switch to staging. If you are already on staging then behaviour may change. Please report issues in the issue tracker using the “Report Issue” button in webconf and feel free to discuss here in this topic any subjects you are not sure are a bug.
To switch to staging:
  • Within webconf, select SOFTWARE->Version. (This was SOFTWARE->Repositories in previous versions of webconf.)
  • From the dropdown list, select “Staging (oram)”.
  • Wait 15 seconds. (This delay has been removed in later version of webconf.)
  • Click “Save”.
  • Select SOFTWARE->Update.
  • Click “Update Software”.
You may wish to reboot after this. It wouldn’t hurt!
If you are using testing (vangelis) then beware that it is about to change significantly with some development of the audio mixer. You may wish to switch to staging (oram) until this has settled down.
Yessss @riban! Come on @zynthianers!
We want the next release to be the best zynthian release ever released. The more stable and fun to use. We need your help to polish those ugly hidden bugs. And we need your comments about the new features and UI improvements. And of course, we want your noise!! So please, send reports, send nice words, and send your zynthian recordings: audio, videos, etc.
I managed to update my V5 as you explained, but my V2 returns 500: Internal Server Error to the Software/Version (http://192.168.1.133//sw-repos) attempt.
                               zynthian-ui: oram-2409.4 (dc1a1c)
                               zynthian-webconf: oram-2409.3 (25cda9)
                               zyncoder: oram-2409.2 (36691b)
                               zynthian-sys: oram-2409.4 (9cf56b)
                               zynthian-data: oram-2409.3 (305b30)
Any hints? Thx
Zynthian is the wonderful result of people willing to create a better world in which peope are enforced to freely express themselves via music and sound!
Great, thanks @riban and all the others.
Question about vangelis’ audio mixer “change significantly”.
What exactly could we expect from this? Side chains? More flexibility? UI change only?
Regards and all the zynthianic love
done (SD was re-flashed)
We already have sidechains. The main change will be to move the mixer strip into the chain and to provide proper send/returns. I am working on merging into vangelis now so hopefully it should land in vangelis over the next few days.
So, I’m still trying to figure what’s wrong with my V2.
(returns 500: Internal Server Error when I attempt to access version on webconf - http://zynthian.local/sw-repos).
I already rebooted and made an update. Of course I can flash sdcard, but I wonder if this is something that should be figured instead of just overcome…
Meanwhile, I noticed there is a small issue. With ssh, I get truncated software versions - just 6 hex chars instead of 7 chars like the webconf.
Should I report this as a bug, or is this a problem between my chair and my screen?
Thx!
Great, I am looking forward to this. One question though:
When I tried vangelis the first (and consequentially the last) time two month ago or so, I ended up in booting into software error and no chance to get to webconf anymore. I finally reflashed the image, because my limited understanding of things.
I recently switched to staging to resolve the endless update notification bug.
As far as I know switching to vangelis rn involves installing and updating some packages (apt) as well.
So here’s my question: If I end up with the same errors, am I able to revert to stable over ssh without reflashing? And how? Otherwise I would maybe just switch to stable right now.
(One p.s.: Is there a technical opportunity having zynthian-my-data on a seperate partition for keeping your user soundfonts on reflashing? I use Zynthian as my keyboard extender and am a big fan of sampled real world instruments, so it’s 30gb for me)
EDIT: Sorry, was not intended as a reply to post #8
I tough the same
I had some trouble with my V3. It seg faulted when running oram-2409.5. I could not resolve this so I updated to staging (oram). It still wasn’t very happy so I did an apt update, apt upgrade and then restarted a couple of times. Now it is running oram okay.
This is usually not the case. We do sometimes break testing (vangelis) because it is the bleeding edge development branch which is why we suggest to only use it for testing and to use a separate boot device. If you are super good with git then you can usually dig yourself out of whatever mess you get into switching between stable. staging and testing. I have to do it all the time but we don’t recommend this for normal people.
Anything is possible.
So if I currently run staging successfully there might be chances I wouldn’t break it appying the announced updates?
Anything is possible. We try really hard to avoid breaking between stable and staging. We try hard (but not quite as hard) to avoid breaking between staging and testing. We bare try at all to avoid breaking between testing and dev branches… :smile:
Following hints you gave to a similar situation last September, I peeked .git/config in zynthian-webconf and, oddly, vangelis was there. although I never gave a try to it. Must be some leftover of last month Oram-2409.3 Stable Point release attempts.
Since i could not succeed with git pull, and after trying apt update and apt upgrade as you mentioned, I gave up and I’m flashing sdcard at this very moment. I better get the box running for rehearsal later today :smiley:
Anyway, V5 seems to be running fine with the 2502 release candidate, so all good.
Thx for your feedback!
Something here reminded me of this quote from Zen and…
"Romantic reality is the cutting edge of experience. It’s the leading edge of the train of knowledge that keeps the whole train on the track. Traditional knowledge is only the collective memory of where that leading edge has been. At the leading edge there are no subjects, no objects, only the track of Quality ahead, and if you have no formal way of evaluating, no way of acknowledging this Quality, then the entire train has no way of knowing where to go. You don’t have pure reason…you have pure confusion. The leading edge is where absolutely all the action is. The leading edge contains all the infinite possibilities of the future. It contains all the history of the past. Where else could they be contained?
I’m in one of the 120 box cars that Pirsig mention. I’m looking out the window, looking ahead towards the locomotive. And i so want to be there. And, from time to time i’m walking from one car to the next, and sit there, relaxing for a while. And then maybe the next hour or week, i move to the next car. And when i look out the window i can see that there are many cars still between me and tho locomotive. And i so want to be there!
I’ve been riding this train for bit more than two months. Thx again to the drivers and what else personnel up there in the locomotive. It’s such a beautiful travel. And it reminds me so much of life itself. I want David Attenborough to bere here talking about it! I want to go on with this nonsens babbel, but i will stop here and excuse my self for being off track (or is it on track? :slight_smile:
I updated to Staging (oram) on my V5 - all went smoothly, after the update I had, for the record:
SOFTWARE
zyncoder: oram (092fb26)
zynthian-ui: oram (c52860c)
zynthian-sys: oram (da7c7f5)
zynthian-data: oram (bee88d0)
zynthian-webconf: oram (4dab315)
Also updated here yesterday, but testing out today i had XRuns problem with Pianoteq!
I’ve opened a topic about it here
For now i just wanted to know if anyone had similar problems?
So far, everything seems to run smoothly here, both on the V2 and V5 official kits.
Nevertheless, I do have a feeling that somehow the rotary encoders are more sensitive than before on V2, making browsing the options faster. For me, the experience didn’t improve, they feel less reliable now, if that makes sense - sometimes I even slip to another selected option in the process of using the switch press…
It seems that my PT problems is unrelated to this topic :slight_smile:
First and foremost, many thanks for all the progress.
Secondly, I would like to apologize for raising the issue here. I simmply do not understand how to post it in the issue tracker.
In another thread I mentioned that after update the update sign remains.
Besides, this is what webconf states:
zynthian-ui: oram (add0179)
With this update there is no difference. I managed to capture an error notification. Maybe it is of use.
Configuration file ‘/etc/dnsmasq.conf’
==> Modified (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** dnsmasq.conf (Y/I/N/O/D/Z) [default=N] ? dpkg: error processing package dnsmasq (–configure):
end of file on stdin at conffile prompt
Errors were encountered while processing:
dnsmasq
E: Sub-process /usr/bin/dpkg returned an error code (1)
Reading package lists…
Building dependency tree…
Reading state information…
