Since I updated to the last version, I noticed some regular cliking noise (every 2 seconds or so).
the noise is not very loud but still audible and It happens with any synth.
Here are my settings:
jackd options: -P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X raw
Soundcard: [HifiBerry DAC+]
I also noticed periodic messages “JACK connection graph change.” within Jackd logs.
It seems to correspond to the interval that the noise is heard.
Attached to this topic is the Jackd debug log file.
We can see that every 2 seconds, the python process performs multiple connections: “startx[610]: Jack: JackClient::Connect src = system:XXXX dst = ZynMidiRouter:main_in” (with XXXX being each midi source).
Thank you very much for the quick feedback. @sadkermit, the Mute parameter ON. I switched them to OFF. But still had the issue with the click (without reboot). Then, I changed the DSP program to something else.
After I reboot, the problem was gone.
Then I tried to set again the old parameters (Mute ON + DSP program), reboot again. But the cliking noise did not come back.
Maybe going through alsamixer settings reseted the audio layer somehow.
Subject solved ! thank you guys again.
