Sorry, I have one problem concerning editing custom ttl.
I tried to do the regrader plugin. I attach what I came up with, don’t try it, it doens’t work (in the end I commented out all changed lines to get at least regrader working again)
regrader_dsp.ttl (10.6 KB)
I obviously didn’t get the use of the @prefix codes.
Unfortunately even after commenting out all edited lines I get on updating this:
Regenerating engines DB: engines ...
lilv_plugin_get_name(): warning: Plugin <http://lvtk.org/plugins/volume> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Ambience> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Bandisto> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/BeatBox> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Combo> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/DeEss> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Degrade> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Delay> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Detune> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Dither> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/DubDelay> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Dynamics> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/EPiano> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Image> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Leslie> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Limiter> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Loudness> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/MultiBand> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Overdrive> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Piano> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/RePsycho> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/RezFilter> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/RingMod> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/RoundPan> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Shepard> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Splitter> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Stereo> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/SubSynth> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/TalkBox> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/ThruZero> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Tracker> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Transient> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/VocInput> has no (mandatory) doap:name
lilv_plugin_get_name(): warning: Plugin <http://moddevices.com/plugins/mda/Vocoder> has no (mandatory) doap:name
INFO:root:Command took 10s
