Hello Zynthianers!
Since after the undervoltage/PSU revolution (see this topic On-Screen Status Info on Zynthian-UI: CPU-load, MIDI-IN, xrun, undervoltage & overtemperature) on my Z it seems almost impossible to cause xruns using Pianoteq, I would like to test it with an higher internal sample rate: apart from doing it from the GUI, any suggestion to tweak permanently the settings (and go back if horrible things start to happen…)? I’m also wondering about two other issues: can the HiFiBerry DAC+ PRO version potentially help in freeing some CPU cycle? And in the event of overheating are the self-adhesive CPU coolers of any use?
As always, thanks for all your help and work!
Andrea
Shudders . . . . ![]()
I stick coolers on to my Pi’s as a matter of course. Can’t say it’s beneficial or not but it shows a little love. . . . .
…eye’s narrow . . . … . ![]()
hold on . . . .![]()
Hello @sadkermit and @wyleu ,
I use the Pi 3B + that came with my kit without an extra heatsink,
but I use the Hifiberry DAC+ PRO XLR with it.
According to the HifiBerry boards overview here,
the DAC+ PRO models only have a dual low-jitter clock generator of their own.
I don’t know how much it affects CPU performance compared to the internal RPi clock handling the audio.
Is there a testmethod other than the performance monitor inside Pianoteq to test it?
I wouldn’t expect any CPU performance difference between DAC+ and DAC+pro. In fact, any I2S device should have the same performance. Using an external low-jitter clock should not make a measurable difference regarding CPU usage.
Quality should be better because of lower jitter, and measuring that could be quite interesting, but you need a good oscilloscope with spectrum analyzer
Thanks @wyleu + @mj_prod + @jofemodo !!
Any suggestion about the Pteq sample rate?
(ps: I
this place!)
I suspect a fair bit is known about the Pteq sample rate round here . . .
Now, recently whilst checking back records it has come to the attention of the authorities ( viz ancient scrolls passim .). That at or about January you reported the click introduced by mis positioned alsa handing… Is this not so?
…and said issue was [Solved] in the mutually agreed fashion…?
Yes…?
Well we have no record of your audio completion submission for this [solved] incident …?
Yeaaahhh.s .
So we require a little musical something in payment of the mutual debts. . . .
and also cos I reckon it will be interesting… !
…there’s pressure …!!
ehm, I will pay my dues, Your Honour, you have my solemn word…
Exxxxcccelllllenttttt… Reaches for unfeasibly large goose quill pen and makes copiously close written notes…
