Just update an enjoy
Hey, thatās very cool!
Do you think it is possible to do something similar for MIDI-IN-events?
Regards, Holger
Of course itās possible
In fact, the canvas used for rendering the CPU-load bar is called āstatus_canvasā and itās intended for showing useful status information ⦠So ⦠we could ābrainstormā and see what should be there
It wants to match logging status.
It could be another webconf advanced display config or itās a benevolent dictator declaration.
Presemably it plays nicely with the undervoltage icons�
I Like midi status up there. Itās a great sanity check in our world.
Great addition. thanks!
Hi @zynthinaners!
As you can read in the new threadās title, iāve improved the new Status Area in the UIās topbar:
- CPU-load => Bar
- MIDI-IN => Green M flag
- Xrun => Red X flag
- Under-voltage => Red V flag
- Over-temperature => Red T flag
The CPU-load bar shows the CPU usage as calculated by Jack:
This is a running average of the time it takes to execute a full process cycle for all clients as a percentage of the real time available per cycle determined by the buffer size and sample rate.
The green M flag is shown when MIDI messages pass thru MIDI router. Not all messages are detected. Only CC, Program Change and Note On/Off.
The red X flag is shown when there are Xruns. You should hear clicks and pops too ![]()
Finally, when the red V or T flag is shown, your zynthian is working in a degraded state, with the CPU frequency capped to 600-800 MHz, trying to stabilize the system and avoid a crash. You shouldnāt see any of them and if you do so, you should consider looking for a better power source (under-voltage) or using a heat sink (over-temperature).
Iām pretty sure that this new on-screen status area will be really useful, specially for detecting common problems, like the under-voltge.
Thatās absolutely cool! Many thanks @jofemodo!!!
Also documented in the Wiki:
http://wiki.zynthian.org/index.php/Zynthian_UI_Users_Guide#The_Status_Area
Bad news: After the new update for the on-screen-status I am getting massive xruns for Pinaoteq
Regards, Holger
Could you reboot your zynthian and try again? My zynthian works OK ā¦
We should be able to hide itā¦I even know where
No, sorry⦠wonāt work also
when I try to update today, I get this:
Extracting templates from packages: 100%
Preconfiguring packages ā¦
dpkg: unrecoverable fatal error, aborting:
files list file for package ālibatk1.0-devā is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
If you update again the error is still there?
Have you tried to install the missing package by hand?
Yes, even after a reboot.
when I install it manually it says, that is it the newest version already.
This is weird as well:
cmake: symbol lookup error: /usr/lib/libjsoncpp.so.0: undefined symbol: _Z^4Nson1rtqledWriteR5uriTeERKNS_ļæ½ValueEļæ½_ZNK4Json5Value5bļæ½ginEv
/usr/bin/cmake: symbol lookup error: /usr/lib/libjsoncpp.so.0: undefined symbol: _Z^4Nson1rtqledWriteR5uriTeERKNS_ļæ½ValueEļæ½_ZNK4Json5Value5bļæ½ginEv
Makefile:298: recipe for target ācmake_check_build_systemā failed
But I try to update my second zynthian nextā¦
the other worked. The former did update as well. I see the M.
Letās see. Maybe that one will be the first getting the first ZynthianOS release.
Hi @C0d3man!
Please, update again and try to disable the status refresh:
/zynthian/zynthian-ui/zynthian_gui.py, line 943
Also, you could disable jack client activation in zynautoconnect:
/zynthian/zynthian-ui/zynautoconnect/zynthian_autoconnect.py, lines 388 & 389
If after this 2 changes you are getting XRuns yet, i doubt itās related with the new Status Area functionality.
From the content perspective:
1/ MIDI Out�
and just for fun . . .
2/ Build a state model that can indicate when there are MIDI events pending. Keep a track of MIDI Onās and Offās display a symbol for overall parsing (Are there any dangling MIDI events that could confuse patch changesā¦, of MIDI stream of the current zynth .)
With MIDI status reporting thatās probably as good as one could get it at the end of the day without running a microphone to detect the sound of the being played by the zynth . . . (Some one will do it
Weāve got the new i/o buttons to respond to messages in the status area, so we want to indicate states that the user can respond to. MIDI panic et al.
Nice! lotās of functionality in a small space.
Lot of possibilities ā¦yes!! But letās take some weeks for testing the current functionality and check that everything works as expected and that the current concept & implementation is the right way before adding more features in this area.
Of course, itās a good moment for brainstorming
Cheers!
Just midi out really, but you did ask!
