Hello guys,
I didn’t use obxd recently very often, but I couldn’t bear anything obxd was producing.
zyncoder: master (e5859ec)
zynthian-ui: master (b7a0f17)
zynthian-sys: master (54a4967)
zynthian-data: master (6712b1c)
zynthian-webconf: master (ecb344c)
Here is what zynthian is outting out when started with zynthian.sh:
root@zynthian:~# /zynthian/zynthian-sys/sbin/zynthian.sh
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.14.93-v7+ #1189 SMP Mon Jan 14 16:52:29 GMT 2019 armv7l
Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jan 27 22:44:58 2019
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
INFO:root:Wiring Layout MCP23017_ENCODERS
DEBUG:root:ZYNCODER A: [102, 105, 110, 113]
DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
DEBUG:root:SWITCHES layout: [100, 103, 108, 111]
DEBUG:root:DISABLED_MIDI_IN = [’’]
DEBUG:root:ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’, ‘QmidiNet:in_1’]
WARNING:root:Using default ENABLED MIDI FB ports
ZynMidiRouter: MIDI tuning frequency set to 440 Hz (8192)
INFO:root:ZYNSWITCHES INIT…
INFO:root:SETUP ZYNSWITCH 0 => wpGPIO 100
INFO:root:SETUP ZYNSWITCH 1 => wpGPIO 103
INFO:root:SETUP ZYNSWITCH 2 => wpGPIO 108
INFO:root:SETUP ZYNSWITCH 3 => wpGPIO 111
INFO:root:STOPPING QMIDINET
DEBUG:root:ZCTRL ‘Layer’: 0 (0 -> 7), None, None
DEBUG:root:Snapshot ‘001’ => MIDI program 0.
DEBUG:root:Snapshot ‘002’ => MIDI program 1.
DEBUG:root:Snapshot ‘003’ => MIDI program 2.
DEBUG:root:ZCTRL ‘Snapshot’: 0 (0 -> 3), None, None
INFO:root:Short Switch 1
DEBUG:root:CLOSE MODAL => snapshot
DEBUG:root:BACK TO SCREEN => layer
INFO:root:Short Switch 3
DEBUG:root:ZCTRL ‘Engine’: 0 (0 -> 14), None, None
INFO:root:REMOTE DISPLAY: localhost:10.0
INFO:root:Starting Engine Jalv/Obxd
DEBUG:root:Plugin Name => Obxd
DEBUG:root:Jack Name => Obxd
INFO:root:No defined MIDI controllers for ‘Obxd’.
INFO:root:Getting Controller List from LV2 Plugin …
DEBUG:root:proc output:
\info_controls
unused => { “index”: 5, “label”: “unused”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
unused2 => { “index”: 6, “label”: “unused2”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
volume => { “index”: 7, “label”: “Volume”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
voicecount => { “index”: 8, “label”: “VoiceCount”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 1.000000, “value”: 1.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
tune => { “index”: 9, “label”: “Tune”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
octave => { “index”: 10, “label”: “Octave”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
bendrange => { “index”: 11, “label”: “BendRange”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
bendosc2only => { “index”: 12, “label”: “BendOsc2Only”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
legatomode => { “index”: 13, “label”: “LegatoMode”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
vibratorate => { “index”: 14, “label”: “VibratoRate”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.600000, “value”: 0.600000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
vfltfactor => { “index”: 15, “label”: “VFltFactor”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
vampfactor => { “index”: 16, “label”: “VAmpFactor”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
asplayedallocation => { “index”: 17, “label”: “AsPlayedAllocation”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
portamento => { “index”: 18, “label”: “Portamento”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
unison => { “index”: 19, “label”: “Unison”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
voicedetune => { “index”: 20, “label”: “VoiceDetune”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
oscillator2detune => { “index”: 21, “label”: “Oscillator2detune”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.400000, “value”: 0.400000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfofrequency => { “index”: 22, “label”: “LfoFrequency”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfosinewave => { “index”: 23, “label”: “LfoSineWave”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfosquarewave => { “index”: 24, “label”: “LfoSquareWave”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfosampleholdwave => { “index”: 25, “label”: “LfoSampleHoldWave”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfoamount1 => { “index”: 26, “label”: “LfoAmount1”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfoamount2 => { “index”: 27, “label”: “LfoAmount2”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfoosc1 => { “index”: 28, “label”: “LfoOsc1”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfoosc2 => { “index”: 29, “label”: “LfoOsc2”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfofilter => { “index”: 30, “label”: “LfoFilter”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfopw1 => { “index”: 31, “label”: “LfoPw1”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
lfopw2 => { “index”: 32, “label”: “LfoPw2”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc2hardsync => { “index”: 33, “label”: “Osc2HardSync”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
xmod => { “index”: 34, “label”: “Xmod”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc1pitch => { “index”: 35, “label”: “Osc1Pitch”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc2pitch => { “index”: 36, “label”: “Osc2Pitch”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pitchquant => { “index”: 37, “label”: “PitchQuant”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc1saw => { “index”: 38, “label”: “Osc1Saw”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 1.000000, “value”: 1.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc1pulse => { “index”: 39, “label”: “Osc1Pulse”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc2saw => { “index”: 40, “label”: “Osc2Saw”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 1.000000, “value”: 1.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc2pulse => { “index”: 41, “label”: “Osc2Pulse”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pulsewidth => { “index”: 42, “label”: “PulseWidth”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
brightness => { “index”: 43, “label”: “Brightness”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 1.000000, “value”: 1.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
envelopetopitch => { “index”: 44, “label”: “EnvelopeToPitch”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc1mix => { “index”: 45, “label”: “Osc1Mix”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 1.000000, “value”: 1.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
osc2mix => { “index”: 46, “label”: “Osc2Mix”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 1.000000, “value”: 1.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
noisemix => { “index”: 47, “label”: “NoiseMix”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filterkeyfollow => { “index”: 48, “label”: “FilterKeyFollow”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
cutoff => { “index”: 49, “label”: “Cutoff”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
resonance => { “index”: 50, “label”: “Resonance”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
multimode => { “index”: 51, “label”: “Multimode”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filter_warm => { “index”: 52, “label”: “Filter_Warm”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
bandpassblend => { “index”: 53, “label”: “BandpassBlend”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
fourpole => { “index”: 54, “label”: “FourPole”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filterenvamount => { “index”: 55, “label”: “FilterEnvAmount”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
attack => { “index”: 56, “label”: “Attack”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
decay => { “index”: 57, “label”: “Decay”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
sustain => { “index”: 58, “label”: “Sustain”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 1.000000, “value”: 1.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
release => { “index”: 59, “label”: “Release”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filterattack => { “index”: 60, “label”: “FilterAttack”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filterdecay => { “index”: 61, “label”: “FilterDecay”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filtersustain => { “index”: 62, “label”: “FilterSustain”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filterrelease => { “index”: 63, “label”: “FilterRelease”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
envelopedetune => { “index”: 64, “label”: “EnvelopeDetune”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
filterdetune => { “index”: 65, “label”: “FilterDetune”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
portamentodetune => { “index”: 66, “label”: “PortamentoDetune”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan1 => { “index”: 67, “label”: “Pan1”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan2 => { “index”: 68, “label”: “Pan2”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan3 => { “index”: 69, “label”: “Pan3”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan4 => { “index”: 70, “label”: “Pan4”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan5 => { “index”: 71, “label”: “Pan5”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan6 => { “index”: 72, “label”: “Pan6”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan7 => { “index”: 73, “label”: “Pan7”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
pan8 => { “index”: 74, “label”: “Pan8”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.500000, “value”: 0.500000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
unused3 => { “index”: 75, “label”: “unused3”, “group”: “(null)”, “points”: [ ], “min”: 0.000000, “max”: 1.000000, “default”: 0.000000, “value”: 0.000000, “is_toggle”: 0, “is_integer”: 0, “is_enumeration”: 0, “is_logarithmic”: 0 }
INFO:root:Getting Preset List from LV2 Plugin …
\get_presets
Vintage Pad => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Vintage_Pad.ttl
Vox Humana => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Vox_Humana.ttl
SYNTH - Polly Jean FB => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/SYNTH___Polly_Jean_FB.ttl
Vangelis Brass (MW) => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Vangelis_Brass__MW_.ttl
Sahara => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Sahara.ttl
Saw Strings IW => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Saw_Strings_IW.ttl
Oberheim Diaries => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Oberheim_Diaries.ttl
Phobos => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Phobos.ttl
PWM Strings 1 IW => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/PWM_Strings_1_IW.ttl
Persuaders => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Persuaders.ttl
Old Stringmachine => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Old_Stringmachine.ttl
PD Reso Satellites => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/PD_Reso_Satellites.ttl
Oxygene Brass IW => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Oxygene_Brass_IW.ttl
PAD - RandnHold FB => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/PAD___RandnHold_FB.ttl
30th anniversary => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/30th_anniversary.ttl
O-Bells 1 IW => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/O_Bells_1_IW.ttl
Influx Strings IW => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Influx_Strings_IW.ttl
OBX goes PPG => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/OBX_goes_PPG.ttl
BP Strings 1 IW => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BP_Strings_1_IW.ttl
Fat Moog Bazz => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Fat_Moog_Bazz.ttl
BzPER_Big Drum (E3) => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzPER_Big_Drum__E3_.ttl
Deimos => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Deimos.ttl
BzBEL_5th Dimnsn - 1 => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzBEL_5th_Dimnsn___1.ttl
BzPAD_Bright Wave => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzPAD_Bright_Wave.ttl
BzBEL_Meditation Bowl => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzBEL_Meditation_Bowl.ttl
BzBRS_Blade Brass => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzBRS_Blade_Brass.ttl
XTFoamPad_-02 => file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/XTFoamPad___02.ttl
DEBUG:root:ZCTRL ‘Channel’: 0 (0 -> 16), None, None
DEBUG:root:BANK LIST =>
[(’’, None, ‘’, None)]
DEBUG:root:BANK INDEX => 0
DEBUG:root:ZCTRL ‘Bank’: 0 (0 -> 1), None, None
INFO:root:Bank Selected: (0)
DEBUG:root:PRESET RESET!
DEBUG:root:PRESET LIST =>
[(‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/30th_anniversary.ttl’, None, ‘30th anniversary’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BP_Strings_1_IW.ttl’, None, ‘BP Strings 1 IW’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzBEL_5th_Dimnsn___1.ttl’, None, ‘BzBEL_5th Dimnsn - 1’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzBEL_Meditation_Bowl.ttl’, None, ‘BzBEL_Meditation Bowl’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzBRS_Blade_Brass.ttl’, None, ‘BzBRS_Blade Brass’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzPAD_Bright_Wave.ttl’, None, ‘BzPAD_Bright Wave’, None), ('file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/BzPER_Big_Drum__E3.ttl’, None, ‘BzPER_Big Drum (E3)’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Deimos.ttl’, None, ‘Deimos’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Fat_Moog_Bazz.ttl’, None, ‘Fat Moog Bazz’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Influx_Strings_IW.ttl’, None, ‘Influx Strings IW’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/O_Bells_1_IW.ttl’, None, ‘O-Bells 1 IW’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/OBX_goes_PPG.ttl’, None, ‘OBX goes PPG’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Oberheim_Diaries.ttl’, None, ‘Oberheim Diaries’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Old_Stringmachine.ttl’, None, ‘Old Stringmachine’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Oxygene_Brass_IW.ttl’, None, ‘Oxygene Brass IW’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/PAD___RandnHold_FB.ttl’, None, ‘PAD - RandnHold FB’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/PD_Reso_Satellites.ttl’, None, ‘PD Reso Satellites’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/PWM_Strings_1_IW.ttl’, None, ‘PWM Strings 1 IW’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Persuaders.ttl’, None, ‘Persuaders’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Phobos.ttl’, None, ‘Phobos’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/SYNTH___Polly_Jean_FB.ttl’, None, ‘SYNTH - Polly Jean FB’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Sahara.ttl’, None, ‘Sahara’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Saw_Strings_IW.ttl’, None, ‘Saw Strings IW’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Vangelis_Brass__MW_.ttl’, None, ‘Vangelis Brass (MW)’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Vintage_Pad.ttl’, None, ‘Vintage Pad’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/Vox_Humana.ttl’, None, ‘Vox Humana’, None), (‘file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/XTFoamPad___02.ttl’, None, ‘XTFoamPad_-_02’, None)]
DEBUG:root:ZCTRL ‘Preset’: 0 (0 -> 27), None, None
INFO:root:Preset Selected: 30th anniversary (0)
ERROR:root:Can’t exec engine command: \set_preset file:///zynthian/zynthian-my-data/presets/lv2/obxd.lv2/30th_anniversary.ttl => End Of File (EOF). Exception style platform.
<pexpect.pty_spawn.spawn object at 0x74bbbef0>
command: /usr/local/bin/jalv
args: [’/usr/local/bin/jalv’, ‘https://obxd.wordpress.com’]
buffer (last 100 chars): b’’
before (last 100 chars): b’JUCE Assertion failure in juce_XmlElement.cpp:72\r\nJUCE Assertion failure in juce_XmlElement.cpp:72\r\n’
after: <class ‘pexpect.exceptions.EOF’>
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 2000
child_fd: 18
closed: False
timeout: 20
delimiter: <class ‘pexpect.exceptions.EOF’>
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
searchwindowsize: None
delaybeforesend: 0
delayafterclose: 0.1
delayafterterminate: 0.1
searcher: searcher_re:
0: re.compile(b’\n> ‘)
DEBUG:root:SET CONTROLLER SCREEN Obxd#1
DEBUG:root:ZCTRL ‘unused’: 0.0 (0.0 -> 1.0), None, None
ERROR:root:Can’t exec engine command: \set_control 5, 0.000000 => End Of File (EOF). Exception style platform.
before (last 100 chars): b’\set_control 5, 0.000000\r\n’
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 2000
child_fd: 18
closed: False
timeout: 20
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
delaybeforesend: 0
DEBUG:root:ZCTRL ‘unused2’: 0.0 (0.0 -> 1.0), None, None
ERROR:root:Can’t exec engine command: \set_control 6, 0.000000 => End Of File (EOF). Exception style platform.
before (last 100 chars): b’\set_control 6, 0.000000\r\n’
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 2000
child_fd: 18
closed: False
timeout: 20
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
delaybeforesend: 0
DEBUG:root:ZCTRL ‘Volume’: 0.5 (0.0 -> 1.0), None, None
ERROR:root:Can’t exec engine command: \set_control 7, 0.500000 => End Of File (EOF). Exception style platform.
before (last 100 chars): b’\set_control 7, 0.500000\r\n’
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 2000
child_fd: 18
closed: False
timeout: 20
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
delaybeforesend: 0
DEBUG:root:ZCTRL ‘VoiceCount’: 1.0 (0.0 -> 1.0), None, None
ERROR:root:Can’t exec engine command: \set_control 8, 1.000000 => End Of File (EOF). Exception style platform.
before (last 100 chars): b’\set_control 8, 1.000000\r\n’
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 2000
child_fd: 18
closed: False
timeout: 20
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
delaybeforesend: 0
ERROR:root:Can’t exec engine command: \set_control 7, 0.496063 => End Of File (EOF). Exception style platform.
before (last 100 chars): b’\set_control 7, 0.496063\r\n’
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 2000
child_fd: 18
closed: False
timeout: 20
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
delaybeforesend: 0
0: re.compile(b’\n> ')
I hope it’s just trivial like a missing ] or something else…
Keep up the good work ad God bless, Marius
