Problem with LV2 plugin DrumSynth preset
I had such a problem with LV2 plugins DrumSynth.
I uploaded ds files to Zynthian. I created an assignment of ds files to individual notes in the DrumSynth GUI. I saved the preset. I searched for lv2 presets in webconf. After the restart, I created a snapshot with DrumSynth on the first channel with the created preset. I ran an external sequencer and nothing. The message WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! => delayed 0.0us
Here is log:
Mar 19 20:46:52 zynthian startx[2315]: [['file:///zynthian/zynthian-my-data/presets/lv2/DrumSynth_DrumSynth_MyClaps.preset.lv2/DrumSynth_MyClaps.ttl', None, 'DrumSynth_MyClaps', 'None'], ['file:///zynthian/zynthian-my-data/presets/lv2/DrumSynth_Owl_Alvarez.preset.lv2/Owl_Alvarez.ttl', None, 'Owl Alvarez', 'None'], ['file:///zynthian/zynthian-my-data/presets/lv2/DrumSynth_TR_808.preset.lv2/TR_808.ttl', None, 'TR-808', 'None'], ['file:///zynthian/zynthian-my-data/presets/lv2/DrumSynth_TR808.preset.lv2/TR808.ttl', None, 'TR808', 'None']]
Mar 19 20:46:52 zynthian startx[2315]: INFO:zynthian_layer.set_preset: Preset selected: Owl Alvarez (1)
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_controller.midi_unlearn: MIDI Unlearn: modulation wheel
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_controller.midi_unlearn: MIDI Unlearn: sustain pedal
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 0 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 1 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 2 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 3 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 4 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 5 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 6 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 7 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 8 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 9 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 10 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 11 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 12 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 13 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 14 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 15 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_audio_recorder.unarm: Channel 256 not armed
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynthian_gui_layer.restore_state_snapshot: Setting curlayer to 0
Mar 19 20:46:53 zynthian startx[2315]: DEBUG:zynthian_gui.set_active_channel: ACTIVE CHAN: -1 => 0
Mar 19 20:46:53 zynthian startx[2315]: INFO:zynseq.restore_riff_data: Restoring RIFF data...
Mar 19 20:46:53 zynthian startx[2315]: ZynCore->setup_behaviour_zyncoder(0, ...): Invalid index!
Mar 19 20:46:53 zynthian startx[2315]: ZynCore->setup_behaviour_zyncoder(1, ...): Invalid index!
Mar 19 20:46:53 zynthian startx[2315]: ZynCore->setup_behaviour_zyncoder(2, ...): Invalid index!
Mar 19 20:46:53 zynthian startx[2315]: ZynCore->setup_behaviour_zyncoder(3, ...): Invalid index!
Mar 19 20:47:38 zynthian startx[2315]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! => delayed 0.0us
type or paste code here
And System and Setup:
HARDWARE
Raspberry Pi 400 Rev 1.1
Audio: Behringer UMC404HD
Display: WaveShare 7 HDMI+USB 1024x600
Wiring: DUMMIES
I2C: Not detected
Profile: encoderless
SYSTEM
Raspbian GNU/Linux 10 (buster)
Build Date: 2024-01-16
Memory: 33% (1272M/3839M)
SD Card: 33% (37G/115G)
Temperature: 51.1ºC
Overclock: None
MIDI
Profile: default.sh
Tuning: 440 Hz
ZS3 (SubSnapShots): On
Preload Presets: On
MIDI to Output: Off
Master Channel: off
SOFTWARE
zyncoder: stable (c452d2b)
zynthian-ui: stable (f19f78c)
zynthian-sys: stable (7a69951)
zynthian-data: stable (5a40e04)
zynthian-webconf: stable (7e74565)
Could you share the preset, the audio files and the snapshot?
Also, be warned that restarting UI sometimes fails. It’s an old issue that we have not managed to fully solve yet.
When facing issues after restarting the UI it’s always recommend a full reboot.
Here is snapshot:
013-DrumSynth.zss (105.7 KB)
and lv2 preset
DrumSynth_Owl_Alvarez.preset.lv2.zip (26.2 KB)
ds files are in /home/pi/zynthian-my-data/files/drumsynth/owl_alvarez
and source is here
No audio sound because no sound from the engine.
I tried restarting, that didn’t help either.
Before first saving the preset and activating it via webconf, DrumSynth was playing.
I tested also DrumGizmo, which generated the same warning Mar 19 22:05:59 zynthian startx[1397]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! => delayed 0.0us, but is making sound.
Geokick is playing OK without this message.
New observation:
The problem occurs when the LV2 plugin DrumSynth is on channel 1. I took a snapshot where the first is ZynAddSubbFX and the second channel is DrumSynth and the problem is over. So it’s kind of an old bug.
EDIT:
OH nooo
But not. After six minutes it appeared and stopped playing.
