RBPi3 Wifi 5GHz support
Alright, after reimaging and then updating software, finally both WiFi and MIDI work perfectly. Phew.
I will note that the web conf tool only listed the 2.4GHz networks in my area, and didn’t list my 5GHz network at all, even though it’s supported by the RasPi 3B+’s chipset. Doesn’t matter overall though, I just hooked it up to my 2.4GHz network and called it a day.
Thanks for the support. Sorry this was such an odyssey. Now I can finally start digging into what this thing can do.
5 GHz band should be enabled. The enabled channels for this band will depends of your location. The device will enable 5GHz channels depending of your country (you can configure it from the Webconf’s Wifi Advanced Config) and the band conditions in your area (it tries to detect radar activity).
Can you send the output of this command:
iw list
Mine is:
root@zynthian:~# iw list
Wiphy phy0
	max # scan SSIDs: 10
	max scan IEs length: 2048 bytes
	Retry short limit: 7
	Retry long limit: 4
	Coverage class: 0 (up to 0m)
	Device supports T-DLS.
	Supported Ciphers:
		* WEP40 (00-0f-ac:1)
		* WEP104 (00-0f-ac:5)
		* TKIP (00-0f-ac:2)
		* CCMP (00-0f-ac:4)
		* CMAC (00-0f-ac:6)
	Available Antennas: TX 0 RX 0
	Supported interface modes:
		 * IBSS
		 * managed
		 * AP
		 * P2P-client
		 * P2P-GO
		 * P2P-device
	Band 1:
		Capabilities: 0x1062
			HT20/HT40
			Static SM Power Save
			RX HT20 SGI
			RX HT40 SGI
			No RX STBC
			Max AMSDU length: 3839 bytes
			DSSS/CCK HT40
		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
		Minimum RX AMPDU time spacing: 16 usec (0x07)
		HT TX/RX MCS rate indexes supported: 0-7
		Bitrates (non-HT):
			* 1.0 Mbps
			* 2.0 Mbps (short preamble supported)
			* 5.5 Mbps (short preamble supported)
			* 11.0 Mbps (short preamble supported)
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 2412 MHz [1] (20.0 dBm)
			* 2417 MHz [2] (20.0 dBm)
			* 2422 MHz [3] (20.0 dBm)
			* 2427 MHz [4] (20.0 dBm)
			* 2432 MHz [5] (20.0 dBm)
			* 2437 MHz [6] (20.0 dBm)
			* 2442 MHz [7] (20.0 dBm)
			* 2447 MHz [8] (20.0 dBm)
			* 2452 MHz [9] (20.0 dBm)
			* 2457 MHz [10] (20.0 dBm)
			* 2462 MHz [11] (20.0 dBm)
			* 2467 MHz [12] (20.0 dBm)
			* 2472 MHz [13] (20.0 dBm)
			* 2484 MHz [14] (disabled)
	Band 2:
			HT20/HT40
			RX HT20 SGI
			RX HT40 SGI
			No RX STBC
			DSSS/CCK HT40
		VHT Capabilities (0x00001020):
			Max MPDU length: 3895
			Supported Channel Width: neither 160 nor 80+80
			short GI (80 MHz)
			SU Beamformee
		VHT RX MCS set:
			1 streams: MCS 0-9
			2 streams: not supported
			3 streams: not supported
			4 streams: not supported
			5 streams: not supported
			6 streams: not supported
			7 streams: not supported
			8 streams: not supported
		VHT RX highest supported: 0 Mbps
		VHT TX MCS set:
			1 streams: MCS 0-9
		VHT TX highest supported: 0 Mbps
		Bitrates (non-HT):
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 5170 MHz [34] (disabled)
			* 5180 MHz [36] (20.0 dBm)
			* 5190 MHz [38] (disabled)
			* 5200 MHz [40] (20.0 dBm)
			* 5210 MHz [42] (disabled)
			* 5220 MHz [44] (20.0 dBm)
			* 5230 MHz [46] (disabled)
			* 5240 MHz [48] (20.0 dBm)
			* 5260 MHz [52] (20.0 dBm) (no IR, radar detection)
			  DFS state: usable (for 299 sec)
			  DFS CAC time: 60000 ms
			* 5280 MHz [56] (20.0 dBm) (no IR, radar detection)
			* 5300 MHz [60] (20.0 dBm) (no IR, radar detection)
			* 5320 MHz [64] (20.0 dBm) (no IR, radar detection)
			* 5500 MHz [100] (20.0 dBm) (no IR, radar detection)
			* 5520 MHz [104] (20.0 dBm) (no IR, radar detection)
			* 5540 MHz [108] (20.0 dBm) (no IR, radar detection)
			* 5560 MHz [112] (20.0 dBm) (no IR, radar detection)
			* 5580 MHz [116] (20.0 dBm) (no IR, radar detection)
			* 5600 MHz [120] (20.0 dBm) (no IR, radar detection)
			* 5620 MHz [124] (20.0 dBm) (no IR, radar detection)
			* 5640 MHz [128] (20.0 dBm) (no IR, radar detection)
			* 5660 MHz [132] (20.0 dBm) (no IR, radar detection)
			* 5680 MHz [136] (20.0 dBm) (no IR, radar detection)
			* 5700 MHz [140] (20.0 dBm) (no IR, radar detection)
			* 5720 MHz [144] (disabled)
			* 5745 MHz [149] (disabled)
			* 5765 MHz [153] (disabled)
			* 5785 MHz [157] (disabled)
			* 5805 MHz [161] (disabled)
			* 5825 MHz [165] (disabled)
	Supported commands:
		 * new_interface
		 * set_interface
		 * new_key
		 * start_ap
		 * join_ibss
		 * set_pmksa
		 * del_pmksa
		 * flush_pmksa
		 * remain_on_channel
		 * frame
		 * set_wiphy_netns
		 * set_channel
		 * tdls_oper
		 * start_sched_scan
		 * start_p2p_device
		 * connect
		 * disconnect
		 * crit_protocol_start
		 * crit_protocol_stop
		 * Unknown command (122)
	Supported TX frame types:
		 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
	Supported RX frame types:
		 * managed: 0x40 0xd0
		 * P2P-client: 0x40 0xd0
		 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * P2P-device: 0x40 0xd0
	software interface modes (can always be added):
	valid interface combinations:
		 * #{ managed } <= 1, #{ P2P-device } <= 1, #{ P2P-client, P2P-GO } <= 1,
		   total <= 3, #channels <= 2
		 * #{ managed } <= 1, #{ AP } <= 1, #{ P2P-client } <= 1, #{ P2P-device } <= 1,
		   total <= 4, #channels <= 1
	Device supports scan flush.
Changed the “Country” line to US and it worked right away.
