Hey jofemodo,
the image is Last-stable zynthianos
Here the new Log after reinstalling
the firmware
Mar 04 18:43:00 zynthian startx[1404]: (EE)
Mar 04 18:43:00 zynthian startx[1404]: Fatal server error:
Mar 04 18:43:00 zynthian startx[1404]: (EE) no screens found(EE)
Mar 04 18:43:00 zynthian startx[1404]: Please consult the The X.Org Foundation support
Mar 04 18:43:00 zynthian startx[1404]: at http://wiki.x.org
Mar 04 18:43:00 zynthian startx[1404]: for help.
Mar 04 18:43:00 zynthian startx[1404]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:43:00 zynthian startx[1404]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:43:15 zynthian startx[1404]: xinit: giving up
Mar 04 18:43:15 zynthian startx[1404]: xinit: unable to connect to X server: Connection refused
Mar 04 18:43:15 zynthian startx[1404]: xinit: server error
Mar 04 18:43:15 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:43:15 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:43:20 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:43:20 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 2.
Mar 04 18:43:20 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:43:20 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:43:20 zynthian startx[1457]: X.Org X Server 1.20.4
Mar 04 18:43:20 zynthian startx[1457]: X Protocol Version 11, Revision 0
Mar 04 18:43:20 zynthian startx[1457]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:43:20 zynthian startx[1457]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:43:20 zynthian startx[1457]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:43:20 zynthian startx[1457]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:43:20 zynthian startx[1457]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:43:20 zynthian startx[1457]: Current version of pixman: 0.36.0
Mar 04 18:43:20 zynthian startx[1457]: Before reporting problems, check http://wiki.x.org
Mar 04 18:43:20 zynthian startx[1457]: to make sure that you have the latest version.
Mar 04 18:43:20 zynthian startx[1457]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:43:20 zynthian startx[1457]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:43:20 zynthian startx[1457]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:43:20 zynthian startx[1457]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:43:20 2021
Mar 04 18:43:20 zynthian startx[1457]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:43:20 zynthian startx[1457]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:43:20 zynthian startx[1457]: (EE)
Mar 04 18:43:20 zynthian startx[1457]: Fatal server error:
Mar 04 18:43:20 zynthian startx[1457]: (EE) no screens found(EE)
Mar 04 18:43:20 zynthian startx[1457]: Please consult the The X.Org Foundation support
Mar 04 18:43:20 zynthian startx[1457]: at http://wiki.x.org
Mar 04 18:43:20 zynthian startx[1457]: for help.
Mar 04 18:43:20 zynthian startx[1457]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:43:20 zynthian startx[1457]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:43:35 zynthian startx[1457]: xinit: giving up
Mar 04 18:43:35 zynthian startx[1457]: xinit: unable to connect to X server: Connection refused
Mar 04 18:43:35 zynthian startx[1457]: xinit: server error
Mar 04 18:43:35 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:43:35 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:43:40 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:43:40 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 3.
Mar 04 18:43:40 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:43:40 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:43:40 zynthian startx[1502]: X.Org X Server 1.20.4
Mar 04 18:43:40 zynthian startx[1502]: X Protocol Version 11, Revision 0
Mar 04 18:43:40 zynthian startx[1502]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:43:40 zynthian startx[1502]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:43:40 zynthian startx[1502]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:43:40 zynthian startx[1502]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:43:40 zynthian startx[1502]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:43:40 zynthian startx[1502]: Current version of pixman: 0.36.0
Mar 04 18:43:40 zynthian startx[1502]: Before reporting problems, check http://wiki.x.org
Mar 04 18:43:40 zynthian startx[1502]: to make sure that you have the latest version.
Mar 04 18:43:40 zynthian startx[1502]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:43:40 zynthian startx[1502]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:43:40 zynthian startx[1502]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:43:40 zynthian startx[1502]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:43:40 2021
Mar 04 18:43:40 zynthian startx[1502]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:43:40 zynthian startx[1502]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:43:40 zynthian startx[1502]: (EE)
Mar 04 18:43:40 zynthian startx[1502]: Fatal server error:
Mar 04 18:43:40 zynthian startx[1502]: (EE) no screens found(EE)
Mar 04 18:43:40 zynthian startx[1502]: Please consult the The X.Org Foundation support
Mar 04 18:43:40 zynthian startx[1502]: at http://wiki.x.org
Mar 04 18:43:40 zynthian startx[1502]: for help.
Mar 04 18:43:40 zynthian startx[1502]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:43:40 zynthian startx[1502]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:43:55 zynthian startx[1502]: xinit: giving up
Mar 04 18:43:55 zynthian startx[1502]: xinit: unable to connect to X server: Connection refused
Mar 04 18:43:55 zynthian startx[1502]: xinit: server error
Mar 04 18:43:55 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:43:55 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:44:01 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:44:01 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 4.
Mar 04 18:44:01 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:44:01 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:44:01 zynthian startx[1538]: X.Org X Server 1.20.4
Mar 04 18:44:01 zynthian startx[1538]: X Protocol Version 11, Revision 0
Mar 04 18:44:01 zynthian startx[1538]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:44:01 zynthian startx[1538]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:44:01 zynthian startx[1538]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:44:01 zynthian startx[1538]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:44:01 zynthian startx[1538]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:44:01 zynthian startx[1538]: Current version of pixman: 0.36.0
Mar 04 18:44:01 zynthian startx[1538]: Before reporting problems, check http://wiki.x.org
Mar 04 18:44:01 zynthian startx[1538]: to make sure that you have the latest version.
Mar 04 18:44:01 zynthian startx[1538]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:44:01 zynthian startx[1538]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:44:01 zynthian startx[1538]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:44:01 zynthian startx[1538]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:44:01 2021
Mar 04 18:44:01 zynthian startx[1538]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:44:01 zynthian startx[1538]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:44:01 zynthian startx[1538]: (EE)
Mar 04 18:44:01 zynthian startx[1538]: Fatal server error:
Mar 04 18:44:01 zynthian startx[1538]: (EE) no screens found(EE)
Mar 04 18:44:01 zynthian startx[1538]: Please consult the The X.Org Foundation support
Mar 04 18:44:01 zynthian startx[1538]: at http://wiki.x.org
Mar 04 18:44:01 zynthian startx[1538]: for help.
Mar 04 18:44:01 zynthian startx[1538]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:44:01 zynthian startx[1538]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:44:16 zynthian startx[1538]: xinit: giving up
Mar 04 18:44:16 zynthian startx[1538]: xinit: unable to connect to X server: Connection refused
Mar 04 18:44:16 zynthian startx[1538]: xinit: server error
Mar 04 18:44:16 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:44:16 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:44:21 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:44:21 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 5.
Mar 04 18:44:21 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:44:21 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:44:21 zynthian startx[1581]: X.Org X Server 1.20.4
Mar 04 18:44:21 zynthian startx[1581]: X Protocol Version 11, Revision 0
Mar 04 18:44:21 zynthian startx[1581]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:44:21 zynthian startx[1581]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:44:21 zynthian startx[1581]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:44:21 zynthian startx[1581]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:44:21 zynthian startx[1581]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:44:21 zynthian startx[1581]: Current version of pixman: 0.36.0
Mar 04 18:44:21 zynthian startx[1581]: Before reporting problems, check http://wiki.x.org
Mar 04 18:44:21 zynthian startx[1581]: to make sure that you have the latest version.
Mar 04 18:44:21 zynthian startx[1581]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:44:21 zynthian startx[1581]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:44:21 zynthian startx[1581]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:44:21 zynthian startx[1581]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:44:21 2021
Mar 04 18:44:21 zynthian startx[1581]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:44:21 zynthian startx[1581]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:44:21 zynthian startx[1581]: (EE)
Mar 04 18:44:21 zynthian startx[1581]: Fatal server error:
Mar 04 18:44:21 zynthian startx[1581]: (EE) no screens found(EE)
Mar 04 18:44:21 zynthian startx[1581]: Please consult the The X.Org Foundation support
Mar 04 18:44:21 zynthian startx[1581]: at http://wiki.x.org
Mar 04 18:44:21 zynthian startx[1581]: for help.
Mar 04 18:44:21 zynthian startx[1581]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:44:21 zynthian startx[1581]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:44:36 zynthian startx[1581]: xinit: giving up
Mar 04 18:44:36 zynthian startx[1581]: xinit: unable to connect to X server: Connection refused
Mar 04 18:44:36 zynthian startx[1581]: xinit: server error
Mar 04 18:44:36 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:44:36 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:44:41 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:44:41 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 6.
Mar 04 18:44:41 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:44:41 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:44:41 zynthian startx[1617]: X.Org X Server 1.20.4
Mar 04 18:44:41 zynthian startx[1617]: X Protocol Version 11, Revision 0
Mar 04 18:44:41 zynthian startx[1617]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:44:41 zynthian startx[1617]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:44:41 zynthian startx[1617]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:44:41 zynthian startx[1617]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:44:41 zynthian startx[1617]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:44:41 zynthian startx[1617]: Current version of pixman: 0.36.0
Mar 04 18:44:41 zynthian startx[1617]: Before reporting problems, check http://wiki.x.org
Mar 04 18:44:41 zynthian startx[1617]: to make sure that you have the latest version.
Mar 04 18:44:41 zynthian startx[1617]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:44:41 zynthian startx[1617]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:44:41 zynthian startx[1617]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:44:41 zynthian startx[1617]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:44:41 2021
Mar 04 18:44:41 zynthian startx[1617]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:44:41 zynthian startx[1617]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:44:41 zynthian startx[1617]: (EE)
Mar 04 18:44:41 zynthian startx[1617]: Fatal server error:
Mar 04 18:44:41 zynthian startx[1617]: (EE) no screens found(EE)
Mar 04 18:44:41 zynthian startx[1617]: Please consult the The X.Org Foundation support
Mar 04 18:44:41 zynthian startx[1617]: at http://wiki.x.org
Mar 04 18:44:41 zynthian startx[1617]: for help.
Mar 04 18:44:41 zynthian startx[1617]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:44:41 zynthian startx[1617]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:44:56 zynthian startx[1617]: xinit: giving up
Mar 04 18:44:56 zynthian startx[1617]: xinit: unable to connect to X server: Connection refused
Mar 04 18:44:56 zynthian startx[1617]: xinit: server error
Mar 04 18:44:56 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:44:56 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:45:01 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:45:01 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 7.
Mar 04 18:45:01 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:45:01 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:45:01 zynthian startx[1662]: X.Org X Server 1.20.4
Mar 04 18:45:01 zynthian startx[1662]: X Protocol Version 11, Revision 0
Mar 04 18:45:01 zynthian startx[1662]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:45:01 zynthian startx[1662]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:45:01 zynthian startx[1662]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:45:01 zynthian startx[1662]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:45:01 zynthian startx[1662]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:45:01 zynthian startx[1662]: Current version of pixman: 0.36.0
Mar 04 18:45:01 zynthian startx[1662]: Before reporting problems, check http://wiki.x.org
Mar 04 18:45:01 zynthian startx[1662]: to make sure that you have the latest version.
Mar 04 18:45:01 zynthian startx[1662]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:45:01 zynthian startx[1662]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:45:01 zynthian startx[1662]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:45:01 zynthian startx[1662]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:45:01 2021
Mar 04 18:45:01 zynthian startx[1662]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:45:01 zynthian startx[1662]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:45:01 zynthian startx[1662]: (EE)
Mar 04 18:45:01 zynthian startx[1662]: Fatal server error:
Mar 04 18:45:01 zynthian startx[1662]: (EE) no screens found(EE)
Mar 04 18:45:01 zynthian startx[1662]: Please consult the The X.Org Foundation support
Mar 04 18:45:01 zynthian startx[1662]: at http://wiki.x.org
Mar 04 18:45:01 zynthian startx[1662]: for help.
Mar 04 18:45:01 zynthian startx[1662]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:45:01 zynthian startx[1662]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:45:16 zynthian startx[1662]: xinit: giving up
Mar 04 18:45:16 zynthian startx[1662]: xinit: unable to connect to X server: Connection refused
Mar 04 18:45:16 zynthian startx[1662]: xinit: server error
Mar 04 18:45:16 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:45:16 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:45:22 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:45:22 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 8.
Mar 04 18:45:22 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:45:22 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:45:22 zynthian startx[1698]: X.Org X Server 1.20.4
Mar 04 18:45:22 zynthian startx[1698]: X Protocol Version 11, Revision 0
Mar 04 18:45:22 zynthian startx[1698]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:45:22 zynthian startx[1698]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:45:22 zynthian startx[1698]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:45:22 zynthian startx[1698]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:45:22 zynthian startx[1698]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:45:22 zynthian startx[1698]: Current version of pixman: 0.36.0
Mar 04 18:45:22 zynthian startx[1698]: Before reporting problems, check http://wiki.x.org
Mar 04 18:45:22 zynthian startx[1698]: to make sure that you have the latest version.
Mar 04 18:45:22 zynthian startx[1698]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:45:22 zynthian startx[1698]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:45:22 zynthian startx[1698]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:45:22 zynthian startx[1698]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:45:22 2021
Mar 04 18:45:22 zynthian startx[1698]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:45:22 zynthian startx[1698]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:45:22 zynthian startx[1698]: (EE)
Mar 04 18:45:22 zynthian startx[1698]: Fatal server error:
Mar 04 18:45:22 zynthian startx[1698]: (EE) no screens found(EE)
Mar 04 18:45:22 zynthian startx[1698]: Please consult the The X.Org Foundation support
Mar 04 18:45:22 zynthian startx[1698]: at http://wiki.x.org
Mar 04 18:45:22 zynthian startx[1698]: for help.
Mar 04 18:45:22 zynthian startx[1698]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:45:22 zynthian startx[1698]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:45:37 zynthian startx[1698]: xinit: giving up
Mar 04 18:45:37 zynthian startx[1698]: xinit: unable to connect to X server: Connection refused
Mar 04 18:45:37 zynthian startx[1698]: xinit: server error
Mar 04 18:45:37 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:45:37 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:45:42 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:45:42 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 9.
Mar 04 18:45:42 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:45:42 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:45:42 zynthian startx[1752]: X.Org X Server 1.20.4
Mar 04 18:45:42 zynthian startx[1752]: X Protocol Version 11, Revision 0
Mar 04 18:45:42 zynthian startx[1752]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:45:42 zynthian startx[1752]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:45:42 zynthian startx[1752]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:45:42 zynthian startx[1752]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:45:42 zynthian startx[1752]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:45:42 zynthian startx[1752]: Current version of pixman: 0.36.0
Mar 04 18:45:42 zynthian startx[1752]: Before reporting problems, check http://wiki.x.org
Mar 04 18:45:42 zynthian startx[1752]: to make sure that you have the latest version.
Mar 04 18:45:42 zynthian startx[1752]: Markers: (–) probed, () from config file, (==) default setting,
Mar 04 18:45:42 zynthian startx[1752]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:45:42 zynthian startx[1752]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:45:42 zynthian startx[1752]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:45:42 2021
Mar 04 18:45:42 zynthian startx[1752]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:45:42 zynthian startx[1752]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:45:42 zynthian startx[1752]: (EE)
Mar 04 18:45:42 zynthian startx[1752]: Fatal server error:
Mar 04 18:45:42 zynthian startx[1752]: (EE) no screens found(EE)
Mar 04 18:45:42 zynthian startx[1752]: Please consult the The X.Org Foundation support
Mar 04 18:45:42 zynthian startx[1752]: at http://wiki.x.org
Mar 04 18:45:42 zynthian startx[1752]: for help.
Mar 04 18:45:42 zynthian startx[1752]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:45:42 zynthian startx[1752]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:45:57 zynthian startx[1752]: xinit: giving up
Mar 04 18:45:57 zynthian startx[1752]: xinit: unable to connect to X server: Connection refused
Mar 04 18:45:57 zynthian startx[1752]: xinit: server error
Mar 04 18:45:57 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:45:57 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:46:02 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:46:02 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 10.
Mar 04 18:46:02 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:46:02 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:46:02 zynthian startx[1866]: X.Org X Server 1.20.4
Mar 04 18:46:02 zynthian startx[1866]: X Protocol Version 11, Revision 0
Mar 04 18:46:02 zynthian startx[1866]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 04 18:46:02 zynthian startx[1866]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 04 18:46:02 zynthian startx[1866]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:E3:40:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 04 18:46:02 zynthian startx[1866]: Build Date: 07 July 2020 09:38:51PM
Mar 04 18:46:02 zynthian startx[1866]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 04 18:46:02 zynthian startx[1866]: Current version of pixman: 0.36.0
Mar 04 18:46:02 zynthian startx[1866]: Before reporting problems, check http://wiki.x.org
Mar 04 18:46:02 zynthian startx[1866]: to make sure that you have the latest version.
Mar 04 18:46:02 zynthian startx[1866]: Markers: (–) probed, (**) from config file, (==) default setting,
Mar 04 18:46:02 zynthian startx[1866]: (++) from command line, (!!) notice, (II) informational,
Mar 04 18:46:02 zynthian startx[1866]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 04 18:46:02 zynthian startx[1866]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Mar 4 18:46:02 2021
Mar 04 18:46:02 zynthian startx[1866]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 04 18:46:02 zynthian startx[1866]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 04 18:46:02 zynthian startx[1866]: (EE)
Mar 04 18:46:02 zynthian startx[1866]: Fatal server error:
Mar 04 18:46:02 zynthian startx[1866]: (EE) no screens found(EE)
Mar 04 18:46:02 zynthian startx[1866]: Please consult the The X.Org Foundation support
Mar 04 18:46:02 zynthian startx[1866]: at http://wiki.x.org
Mar 04 18:46:02 zynthian startx[1866]: for help.
Mar 04 18:46:02 zynthian startx[1866]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 04 18:46:02 zynthian startx[1866]: (EE) Server terminated with error (1). Closing log file.
Mar 04 18:46:17 zynthian startx[1866]: xinit: giving up
Mar 04 18:46:17 zynthian startx[1866]: xinit: unable to connect to X server: Connection refused
Mar 04 18:46:17 zynthian startx[1866]: xinit: server error
Mar 04 18:46:17 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 04 18:46:17 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 04 18:46:22 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 04 18:46:22 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 11.
Mar 04 18:46:22 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 04 18:46:22 zynthian systemd[1]: Started Zynthian User Interface.
Mar 04 18:46:22 zynthian startx[1903]: X.Org X Server 1.20.4
Mar 04 18:46:22 zynthian startx[1903]: X Protocol Version 11, Revision 0
Thanks for help
Marco
