You have to create 16 channels of the maestro_concert_grand_v2_pb.gig [0] Instrument. Every channel listens to one MIDI channel. Thats because the earlier mentioned pitch bend message affects every note played back via this channel.
The ZynAddSubFx engine supports microtonal rescaling, although it’s not available in the zynthian UI but I’m not sure if it works with scalar files. The desktop ui does look like it can import .scl files though.
samplv1 appears to support it although that’s not an available engine yet.
ZynAddSubFX => FYI, currently you can load microtonal scale files for ZynAddSubFX from the Zynthian-UI. You only have to copy them to the right folder
Pianoteq => We should check if we can load scala files to Pianoteq via command line. If not, it seems to support MTS (MIDI Tuning Standard), so we could use this way.
