Shortcut (CUIA / OSC) to quickly switch to sequencer or other pages?
I want to switch to the sequencer window with one press of a button and regardless from where I am in the Zynthian menu structure. Is this possible via OSC messages ? I had a look at the CUIA description in the manual, and found nothing except the “MODAL_STEPSEQ” command. Sending this command does nothing in my case. For clarification: All other OSC commands that I use do work without problems, so it’s not an OSC problem.
Hi @catherder! Yes, there are CUIA commands to directly access each view:
  • SCREEN_MAIN
  • SCREEN_ADMIN
  • SCREEN_AUDIO_MIXER
  • SCREEN_SNAPSHOT
  • SCREEN_MIDI_RECORDER
  • SCREEN_ALSA_MIXER
  • SCREEN_ZYNPAD
  • SCREEN_PATTERN_EDITOR
  • SCREEN_ARRANGER
  • SCREEN_BANK
  • SCREEN_PRESET
  • SCREEN_CALIBRATE
  • SCREEN_CONTROL
  • CHAIN_OPTIONS
  • MENU
  • PRESET
  • PRESET_FAVS
You can also toggle a view by passing the view name to CUIA command TOGGLE_VIEW.
You can show a view by name by passing the view name to CUIA command SHOW_VIEW.
I guess you have found MODAL_STEPSEQ on the wiki or somewhere? Maybe you would like to update that or at least point us to the wrong info.
I have no account for the wiki and user registration is disabled. However, these are the pages where the ‘MODAL’ call are still used:
https://wiki.zynthian.org/index.php/Zynthian_UI_Users_Guide#CUIA:_Callable_UI_Actions
They are in the “Controlling the UI with MIDI messages” section.
https://wiki.zynthian.org/index.php/Accessing_Zynthian_from_your_computer#OSC
This pages uses ‘MODAL’ as well.
