Hi @zynthianers!
I’ve found this fantastic site, that is a blow of fresh air and inspires my creativity for future kit improvements:
Hi @zynthianers!
Yeah, really nice. I particulary appreciate the way where the excellent job is mixed with some dirty looks
This could also be inspiring: RPI compute module is out !
The new compute module looks good & the pricing is great. They have changed the main connector from the earlier compute module; it still looks like a difficult connector to solder to a daughter board. A Zynthian daughterboard with audio codec, encoders and I/O connectors would be fun to design… but hard to specify & assemble.
Would be neat if someone made a compute module hat. That would be an interesting expansion.
Using the compute module would allow more compact design and plays well to the product rather than project but it has disadvantages. Compute modules tend to arrive more than a year after the standard board which can delay development of new features. It is less accessible for hobbiests, i.e. needs extra hardware (motherboard) to expose its interfaces.
If @jofemodo wanted to produce the main product with the compute module then we could have a slightly better / more customised solution but I imagine this may not appeal too much, requiring extra effort to create and support the motherboard and distancing the product from us enthusiasts with a Pi. I would love for this to happen, i.e. the official product consists of a board (replacing the all-in-one) which hosts the interfaces and accepts a CM4 whilst everything continues to support the standard Pi4. In fact, it would be nice for a future incarnation of the all-in-one board to do both, i.e. have the CM4 connections and ability to connect to a standard Pi. Ooh! That would be nice. The Kicad files are available for the CM4 development board from which custom designs like this could be adapted. I am starting to like this idea…
Using https://geppetto.gumstix.com one can try to extend and modify one of their products like this one https://store.gumstix.com/manufacturer/raspberry-pi/cm4-development-board.html
I gave it a try:
On board there is an audio codec (+ 2 lines in, headphone and stereo line out), hdmi, ethernet, dsi connector, 4USB2, 4 headers connected to gpios for encoders (more about that below), and a M2 ssd connector, power is done trough a barrel jack and they are 2 regulators 5V 5A, 3.3V 1.5A
The set up fee of 1999$ will not be applied, see here: https://www.gumstix.com/special-offer
Pro:
Cons:
Note: I’ve edited the post, add a stereo line out, remove my email adress from screenshot
My favourite new kit at the moment would be an encoder & switch set that could connect to a zynth via USB, so a remote panel would be easily implemented.
I want to add a PEZ dispenser.
There is no need to use a compute module, if what you want is a smaller footprint this is a good starting point https://github.com/okyeron/fates
It uses a normal Rpi 4 and the majority of it’s connectors but breaks out some of them to the back and adds the screen, encoders and DAC/ADC
Maybe there could be a slimmed down version of the dac/adc + zynscreen + midi circuit to get a slim build in one pcb + rpi or maybe 2 pcbs + rpi.
I myself tried this slimming down concept on mine, getting somewhat of a slim solution (the cabling an the midi+extension pcb were the main things i couldn’t get any thinner), and i definitely see a point in doing something like this but still supporting the DIY way.
I was thinking that maybe the midi circuitry could be integrated within zynscreen and maybe make a breakout for the extra boards if you needed them (As to avoid the 40 pin cable as much as possible).
Wiimote integration as an expression controller and/or drum sticks.
