Thanks for the welcome, @jofemodo. The display is a Kuman 3.5" display. I adjusted the laser cutter files to fit it. I also used the laser cutter to cut a recess on the back side of the display panel for the display to sit in. I didn’t like the look of the display sitting 3 mm below the top surface. Plus, the recess helps secure the display. The display has a fairly long female header so I also increased the height of the box by 6 mm to accommodate. I built a new case that incorporates all these features. The display is a waveshare 35a, so I just selected the correct driver from the Zynthian setup menu and it worked! Very chuffed about that! Thanks so much for all your efforts on this project. Now all I have to do is figure out all the features! Here are 2 photos of my Zynthian. I’ll add another two in a second post.
