Superlooper tutorial
Just to bounce this back up to the top and post a link to @Baggypants video…
Which I have to find first. . .
Here’s the thread it was in . . . .
This one…
It’s good when it joins up like that.
The original sooperlooper was based on Echoplex Digital Pro & this is it’s footswitch.
Infuriatingly 7 buttons ( I have a six button footbox)
RECORD
Start here. If the record threshold is all the way down, pressing it once will start recording and pressing again will end the recording.
If the Threshold is set higher the loop recording doesn’t start until the audio data is greater than the threshold. When finishing the loop, the threshold value is ignored. See the tips in the EDP manual, it works best if you stop and start recording the moment you hit the downbeat, not before. Trust them.
Special Endings
  • If you end a RECORD with another function (OVERDUB, MULTIPLY, REPLACE, SUBSTITUTE, INSERT, ONCE) it will finish the loop immediately (threshold ignored) and start doing the new function.
  • Ending with REVERSE stops recording and plays the loop backwards once then goes into MUTE mode.
OVERDUB
This keeps playing the loop and adds whatever you play on top until you stop overdubbing. Very useful… this is the main tool. The Feedback controls the amount of the original loop that is used every pass. In actuality, when Feedback is set to 100%, it uses a slightly less amount to help prevent clipping on output.
MULTIPLY
This similar to overdub, except the original loop is repeated underneath you “multiplying” the loop length until you stop it. Thus it can turn a 1 measure loop into a 2,3, etc measure loop. QuantizeMode and RoundMode affect how the overdubbing starts and stops. QuantizeMode affects when the operation begins, and RoundMode affects if the new audio continues to be added throughthe end of the current cycle after hitting the final record.
Keep in mind that the original loop length is a “cycle” and the loop length will be a multiple of that. You can actually make an already multiplied loop have fewer cycles when using Multiply on loops that have already been multiplied.
Special Endings
  • If you end a MULTIPLY with a RECORD press it ends the loop immediately and resets the cycle length to the whole loop.
  • The MultiIncrease function is implemented which allows you to increment the cycle count ahead of time, without needing to wait until the exact time to finish the multiply. Basically, press Multiply as if you were finishing it, then before the current cycle plays out, press Multiply again repeatedly to add cycles. The multiply will resume and automatically go into playback after the specified number of cycles.
INSERT
It inserts new input in place, but always one “cycle” length… QuantizeMode and RoundMode have effects similar to Multiply.
Special Endings
Ending with a RECORD press it ends the operation immediately and resets the cycle length to the whole loop.
MUTE
Press to mute loop output. Dry passthough audio will be unaffected. To continue playing the loop in time press MUTE again. To continue playing the loop from the top press TRIG. To play back the loop once and return to mute, press ONCE.
UNDO
Restores the playing loop to the state before the last operation. It maintains the current time position if the current loop was based on the previous loop (eg, not newly recorded). You can go all the way back to the first one still intact within the loop memory. As more operations are done, more of the available loop memory is used, and it will eventually start reclaiming the oldest versions.
Note that to undo all existing state, do a long-press of Undo.
Pressing Undo when an operation is waiting for sync or quantization will cancel the pending operation.
NEXT LOOP
[g.ctrl] select_next_loop
Select the loop after the currently selected one. When it reaches the last it loops back to the first.
And here’s a relevant post on another more or less relevant bit of Zynthian sooperlooper interaction.
