gitnob
June 16, 2024, 1:43pm
1
I updated oram today. Timing is set to midi clock syncing.
I use external controller to sync zynthian’s clock.
Now reboot. Go to tempo settings. Without changing anything. start external controller and change bpm of external midi sync.
→ No change in zynthian’s tempo settings.
Switch “Clock source” from “midi” to something else and back to “midi”.
Change tempo of external midi controller again.
→ Zynthian is following the change.
My suggestion: initialization of “tempo settings” “clock source” state not restored correctly during boot process. I tried it on V4 and V5, same issue.
Anybody else can confirm?
Hi @gitnob !
I can confirm the issue. Please, open a ticket in our system and we will fix ASAP.
gitnob
June 16, 2024, 2:53pm
3
Done! You can mark it as bug.
It’s a pleasure.
a breadcrumb for searchers:
opened 02:51PM - 16 Jun 24 UTC
closed 07:54PM - 19 Jun 24 UTC
Bug
# Describe the issue
"Clock source" state in "Tempo settings" not restored on b… oot/reboot.
# To Reproduce
## Steps to reproduce the behavior:
1. Set Timing to midi clock syncing (in "Tempo settings" at "clock source".
2. Use external controller to sync zynthian’s clock.
3. Reboot.
4. Go to tempo settings. Without changing anything.
5. Start external controller and change bpm of external midi sync.
6. Switch “Clock source” from “midi” to something else and back to “midi”.
7. Change tempo of external midi controller again.
## Expected behaviour
State of "clock source" initialized after boot/reboot process.
## Actual behaviour
State not restored, but shown in zynscreen.
# Additional context
Forum: https://discourse.zynthian.org/t/syncing-to-external-midi-clock-shown-on-zynscreen-but-not-set-after-boot-reboot/9700
# Configuration
## Hardware
Raspberry Pi 4 Model B Rev 1.2
Audio: HifiBerry DAC+ ADC PRO
Display: ZynScreen 3.5 (v1)
Wiring: MCP23017_ZynScreen
I2C: MCP23017@0x20
Profile: v4_stage
## System
Build Date: 2024-02-01
Memory: 15% (594M/3792M)
SD Card: 24% (14G/58G)
Temperature: 52.5ºC
Overclock: None
## MIDI & UI
Tuning: 440 Hz
Master Channel: Off
Preload Presets: On
ZS3 (SubSnapShots): On
Power Save: 0 minutes
Audio Levels on Snapshots: On
## Software
zyncoder: oram (e0014fe)
zynthian-ui: oram (e01d4b9)
zynthian-sys: oram (8602194)
zynthian-data: oram (e222e11)
zynthian-webconf: oram (2dba270)
“Clock source” state in “Tempo settings” not restored on boot/reboot. #1091 - Closed
gitnob opened this issue Jun 16, 2024
