The linked kernel discussion suggests the problem may lie in the device tree and how the control line are selected. It suggests the kernel issue is resolved and that overlays must be correctly selected. Maybe there is another issue I missed.
For me I get problem with USB on the RC2 so I will (try)
YES ! working again…
Thanks…
Another issue, with the RC3 and the e1050e94821a70b2e4c72b318d6c6c968552e9a2 kernel is the USB Midi Keyboard been detect ONLY if plugged AFTER bootup…
If the USB Keyboard stay connected at boot, it will not been detected at all, also if moved from the USB port to another USB port…
tryed with a fresh new Kit V4 and a RPiv4
Hi! We have a new green build and it should be functional:
https://os.zynthian.org/2020-08-08-zynthianos-buster-lite-armhf-1.0.0.zip
Stop downloading and testing this image. It’s not workig OK…
I would like to test this image as a candidate for RC3 (RC3C
) and ask for your help, beloved community as, due to the “New Subnormality”, i’m still living on a little country house with only 4G connectivity, quite limited for downloading SD images … so … if you download, test and the basics are working OK, i will download and test in detail.
I had to use
sudo rpi-update e1050e94821a70b2e4c72b318d6c6c968552e9a2
to get the display on v4 running.
Thanks @C0d3man !
Zynthianers, please, stop downloading and testing the latest image. It’s not workig OK…
Yeah, the ch_high issue was only merged 5 days ago so you need the bleeding edge firmware you get from rpi-update.
OK @zynthianers!
I would like to propose a new candidate for RC-3 (must i say RC3C?
https://os.zynthian.org/2020-09-03-zynthianos-buster-lite-armhf-1.0.0.zip
It should work out-the-box on v3 & v4 oficial kits. Older or customized kits would need to configure the hardware from webconf.
Please, download and test, test & test!!
Thanks for helping!!
Here are some results so far from the testing of this image (from a new SD card) on a V4 kit:
Boot & screen detection on V4 kit is ok!
Alsa Mixer out of the box doesn’t show what it should:
it’s initially configured as “Digital,ADC,ADC Left Input,ADC Right Input” and shows just 2 controls: ADC Left Input and ADC Right Input" (ignoring the first 2 entries, which seem to be impling Left/Right varieties but not correctly detected.
Correcting this in the webconfig to something along the lines of “ADC Left,ADC Right,ADC Left Input,ADC Right Input,Digital Left,Digital Right” or another ordering gives the original 6 controls back.
exfat USB disks are not detected/used. (Seriously, try buying and USB disk with any capacity from a major brand that’s not formatted as exfat. To me this is a flaw, and shouldn’t be solved by reformatting). The package exfat-utils is installed by default, but not providing the intended services.
(Something related; the default naming of snapshots includes “>”, which is not filename friendly at all, and downright impossible on (ex)fat(32) filesystems.)
I tried a few Synths, no real isues detected.
What audio effects that are configured by default are recommended for something as basic as a simple Mono->stereo conversion? I have settled on Calf Haas Stereo Enhancer and Calf Stereo Tools, both of which are not activated by default.
Please fix:
- the initial ALSA configuration (rather crucial)
- the exfat usb support (nice to have, not essential)
Yes. I see. It can be solved easily by a software update, although it’s suboptimal.
Sorry, this has never been supported. It’s not a flaw. If someone finds a way of configuring the “fuse exfat” driver for automounting an USB disk, i will integrate it. Until then, try to convince M$ to release the patent pending on exfat, so the driver can be included on the linux kernel ![]()
It’s already fixed ![]()
Thanks for testing!
I don’t think exfat support should block the RC. It is additional functionality hence can be bumped to next release. Nice to have but does not stop Zynthian working at least as well as it has.
Sure, this can wait until later.
Automatic mounting of exfat usb drives turns out to be less trivial than expected it seems.
I played around with it for a day now, didn’t detect any showstoppers.
There are a large number of plugins, especially Audio Effects
Not all plugins work though, but those can most likely be fixed through an update.
(For example the Drum Synth Geonkick (activated by default?) starts without any controls, and doesn’t respond to midi.)
Did anybody else test the image?
OK @zynthianers!
This image is identical to the 2020-09-03, but fixes the little problem with the Mixer:
https://os.zynthian.org/2020-09-05-zynthianos-buster-lite-armhf-1.0.0.zip
Please, test with it and if nobody find critical issues, it will be the RC-3.
I can feel we are really close to release a stable image, that should last for a long time
Hi @jofemodo, is there something like a test procedure, a protocol or something? Or is it just using it and reporting issues?
As soon as my v4 arrives I will test/use this build. If this build does not become RC3, do I need to install a new build afterwards or do I just need to perform an update?
Cheers,
Johann
OK guys! It’s official now!
The nightly build from 2020-09-05 is the Buster RC-3, the new official Zynthian SD-image:
I’ve updated links on web & wiki. Please, warn if you detect an outdated link to older images.
Enjoy!!
