hi there my capacitive 2.8 touchscreen has stopped responding after last update have used
:dmesg | grep -i FT5406
and get no devices found???
thanks
There some important changes in the configuration system. What is the exact model of your screen? Where did you load your touch-device driver before the update?
hi there thanks for the reply i have an adafruit pitft2.8 resistive. before the update i didnt need to load anything it just worked right off the bat
In the first post you say “capacitive” … ![]()
Please, update your software following these instructions:
Also, you could download the last image:
http://blog.zynthian.org/download/zynthian_gorgona_edge_rbpi3_piscreen2-2017-10-23.img.torrent
and simply udpate after burning.
It comes preconfigured for the new kits, so you will need to re-configure some options for getting it to work with your hardware:
- Display: PiTFT 2.8’ Resistive
- Wiring Layout: PROTOTYPE-4
- Font Size: 10
thanks but getting this error whilst trying to update:-
root@zynthian:~# /zynthian/zynthian-sys/scripts/update_zynthian.sh
Updating zynthian-sys …
Already up-to-date.
Updating System configuration …
SOUNDCARD CONFIG => dtoverlay=hifiberry-dac
DISPLAY CONFIG => dtoverlay=pitft28-resistive,rotate=90,speed=32000000,fps=20
cp: cannot stat ‘/zynthian/zynthian-sys/etc/udev/rules.d/*’: No such file or directory
Custom Config /zynthian/zynthian-sys/custom/display/PiTFT 2.8 Resistive …
Updating zynthian recipes …
Executing /zynthian/zynthian-sys/scripts/recipes.update/01_setup_zynthian_multilayer.sh …
Already upgraded to multilayer!
Executing /zynthian/zynthian-sys/scripts/recipes.update/02_setup_zynthian_webconf.sh …
Already upgraded to webconf!
Executing /zynthian/zynthian-sys/scripts/recipes.update/03_setup_zynthian_master.sh …
Already upgraded to master!
Executing /zynthian/zynthian-sys/scripts/recipes.update/04_setup_zynthian_edge.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_dexed_dcoredump.sh …
From https://github.com/dcoredump/dexed
- branch native-lv2 -> FETCH_HEAD
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_linuxsampler.sh …
Already updated to linuxsampler-2.0!
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_modui.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_setBfree.sh …
Updating zyncoder …
Already up-to-date.
++ Defined HAVE_WIRINGPI_LIB
++ Using wiringPI
– Configuring done
– Generating done
– Build files have been written to: /zynthian/zyncoder/build
[ 50%] Built target zyncoder
[100%] Built target zyncoder_test
Updating zynthian-ui …
Already up-to-date.
Updating zynthian-webconf …
root@zynthian:~#
There is no “real” error. This message is normal and i should remove it:
Everything seems to be correctly updated
many thanks still not able to get the touch part of my display working as before and sadly unable to use new image as running on rpi2. cheers anyhow
