Have you found the problem?
If you want to play zynaddsubfx from MIDI Chord then add MIDI Chord effect to the zynadsubfx on layer 1 by bold press to access context menu and add MIDI Effect.
Yes, adding MIDI fx on an instrument layer works well.
My problem was in:
#1 “zynaddsubfx”
#2 “Midi Chord” MIDI routed to #1
But I think that it could be my error: what comes out of layer #2 is on channel 2. If I send it to layer 1, I need to map it to channel 1 with a channel mapper pluggin (and then it works well)
Finally, midi out works! That’s great
it was due to the leds that I had not installed!
Thank you all for the help and answers!
Greetings
Marco
