hi, using an external usb audio device, audio input is usable on zynthian?i speak in general, 'cause even changing on webconf, usb device is never used. System recognizes device correctly (it’s shown on alsamixer with all parameters) but, for example, inside MOD, no audio input or output appears except for hifiberry’s out.
there’s something still not ready and need a manual adjustment, or i’m doing something wrong?
Hi @ivanmonterosso!
Are you trying to use 2 audio devices with Zynthian? It wont work by default …
It’s a complex matter, but generally is not a good idea to use Jack Audio with 2 different devices simultaneously. Anyway, you can try by tweaking the “jackd” options. I haven’t tried recently and who know …
Good luck!
Thanks for reply… however i want use Just One at once… would try the USB with input, but sound remains on hifiberry. I tried to change hw id on jack string present on webconf field, but nothing changed… Maybe i have to change It dierctly in terminal?
Could you send your “/boot/config.txt”?
Sure, l Will do tomorrow
but, here can’t upload txt… do i have to paste it here?
You can use “preformated text” to post code !
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# Tell bootloader to use initram image
#initramfs initrd.img-4.1.13-v7+
# Load RT Kernel for RBPI2
#kernel=kernel7-rt.img
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
# Disable Splash Screen
disable_splash=1
# Disables dynamic frequency clocking
force_turbo=1
# Uncomment to overclock the arm. 700 MHz is the default.
[pi2]
arm_freq=900
core_freq=250
sdram_freq=450
over_voltage=2
[all]
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Disable Blutooth Support for HifiBerry compatibility with RBPi 3
# Swap back the ttyAMA0 to GPIO
[pi3]
dtoverlay=pi3-disable-bt
dtoverlay=pi3-miniuart-bt
[all]
# Enable MMAP support (Jackd, etc.)
dtoverlay=i2s-mmap
# Soundcard Config
# Display Config
dtoverlay=pitft28-resistive,rotate=90,speed=32000000,fps=20
# Adjust Serial Port Clock to allow MIDI baudrate 31250
[pi2]
init_uart_clock=2441000
init_uart_baud=38400
dtparam=uart0_clkrate=3000000
[pi3]
init_uart_clock=39062500
dtparam=uart0_clkrate=48000000
[all]
It seems OK. Hifiberry driver is not loaded, so USB device should be the only one …
Can you send the “lsmod” command output?
sure,
here it is:
Module Size Used by
brcmfmac 222874 0
brcmutil 9092 1 brcmfmac
cfg80211 543027 1 brcmfmac
snd_usb_audio 147900 2
snd_hwdep 6688 1 snd_usb_audio
snd_usbmidi_lib 22487 1 snd_usb_audio
rfkill 20851 2 cfg80211
snd_rawmidi 23790 3 snd_usbmidi_lib
fb_ili9340 3647 1
fbtft 34966 1 fb_ili9340
snd_seq_device 5504 1 snd_rawmidi
syscopyarea 3225 1 fbtft
sysfillrect 3826 1 fbtft
snd_soc_pcm512x_i2c 2718 1
snd_soc_hifiberry_dacplus 5055 2
snd_soc_bcm2835_i2s 6546 2
sysimgblt 2480 1 fbtft
snd_soc_pcm512x 21992 1 snd_soc_pcm512x_i2c
fb_sys_fops 1741 1 fbtft
snd_soc_core 179915 3 snd_soc_pcm512x,snd_soc_hifiberry_dacplus,snd_soc_bcm2835_i2s
snd_compress 10384 1 snd_soc_core
evdev 12423 2
snd_pcm_dmaengine 5894 1 snd_soc_core
joydev 9988 0
snd_pcm 98501 6 snd_soc_pcm512x,snd_usb_audio,snd_pcm_dmaengine,snd_soc_hifiberry_dacplus,snd_soc_core
snd_timer 23968 1 snd_pcm
gpio_backlight 3105 0
snd 70032 14 snd_compress,snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_soc_core,snd_pcm
i2c_bcm2835 7167 1
bcm2835_gpiomem 3940 0
spi_bcm2835 7596 0
clk_hifiberry_dacpro 2812 1
uio_pdrv_genirq 3923 0
uio 10204 1 uio_pdrv_genirq
fixed 3285 0
i2c_dev 6913 2
stmpe_ts 4779 0
ipv6 408971 26
just keep in mind another thing i noticed: with USB audio plugged in, and USB audio device is choosen on webconf, after reboot the page is this way (without any volume control)
and zynthian unable to load the default shapshot…and if trying to force load, it gives the splashscreen with “red error”.
after a second reboot , webconf page looks this way, theorically right, but sound remanis on hifiberry.
If i pull out usb device, but remain in USB device setup, then reboot, no more error occours, and webconf page stays in this way.
Obviously sound is on hifiberry, the only one board present
That’s very strange. The HifiBerry drivers are loaded and it shouldn’t be, as there is no “dtoverlay” for that in your “boot/config.txt”. Please, can you check again your “boot/config.txt”?
by now i’m trying several things with original setup for other issues… i will reproduce again from scratch by inserting usb device, choosing from webconf, rebooting etc… then give you bootconfig… it’s ok?
Correct
After booting, send your “boot/config.txt” and the “lsmod” output …
want to know a joke?.. zynthian turned off. USB device inserted, still on hifiberry, (webconf was still on USB device with no success), changed to hifiberry, rebooted,…this is config.txt
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
#dtoverlay=lirc-rpi
[pi3]
[all]
dtoverlay=i2s-mmap
# Soundcard Config
dtoverlay=hifiberry-dacplus
# Display Config
[pi2]
[pi3]
[all]
this is lsmod:
Module Size Used by
brcmfmac 222874 0
fb_ili9340 3647 1
snd_soc_hifiberry_dacplus 5055 0
snd_usb_audio 147900 5
evdev 12423 2
joydev 9988 0
snd_pcm 98501 7 snd_soc_pcm512x,snd_usb_audio,snd_pcm_dmaengine,snd_soc_hifiberry_dacplus,snd_soc_core
snd 70032 15 snd_compress,snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_soc_core,snd_pcm
i2c_bcm2835 7167 1
spi_bcm2835 7596 0
fixed 3285 3
i2c_dev 6913 2
stmpe_ts 4779 0
ipv6 408971 26
Sound is on USB
And… most of all: MOD has audio input present
Woooooaoooo!!
This is a problem with the ALSA subsystem and the way devices are sorted. As i told you, connecting 2 different audio devices to zynthian will be quite tricky.
Anyway, there are documentation about how to change the order of devices. For instance:
Alsa Opensrc Org - Independent ALSA and linux audio support site
regards
Yes, i noticed … For me only one is enough… Will finally experiment with audio input and… That veery interesting audio>midi function
And very experimental too … jeje! Probably you would like to “tune” the audio=>MIDI conversion parameters.
yes, would tune… any tips where to change them?
thanks
Try this file:
/etc/systemd/system/aubionotes.service
But your changes will be overwirten everytime you update the software. We should add this to webconf tool
create github tasks…
