Which image are you using?
I broke webconf the day before yesterday. What is your build label? Have you updated via zynthian-ui to latest?
Same here! Thanks @riban!
Yes I drummed it in with the keyboard. That makes it so āaliveā.
Like the Encoders a lot now
Iād like to make small initial sequences longer by banging the encoder clockwise against the right hand side, but I can imagine all the hassle of representing that in touch so just a thought.
Touch screen use.
The sounding keys and the screen transpose work well but are a little noisy to my ears. Feels like it needs a gesture o expand the zoom to set the scale of the canvas you are using.
The population of the menu functions seems to lag selected display so one goes to set a no of steps and the value seems to be ( on occasion up in the 50ās, not quite sure on this one, anyone else seen it after setting steps per beat ? ). Then you have an awful lot of screen refreshes to watch to get it back down to a sane number. But we know the menus aināt finessed yet.
Where are the longest redraws anyone can find in the interface �
The Pad Trigger mode becomes more intriguing in light of transpose & copy, Perhaps transpose could combine the two and upon transposition duplicate the existing pattern into the next available cell on the Pad Trigger.
Pad Trigger Display would benefit from some differentiation between patterns that exist and those that donāt , see above comment about transpose ( It gives composer/arrangers a quick way of laying out a musical idea then transposing and modifying it to try the differing patterns against each other quickly. Imagine playing with various key changes to decide a chord sequence and developing a piece from thereā¦
Pad Trigger would need a delete.
But lets get it past the āI feel loveā test first
Instantiation of new pattern instances, are they copies of the existing selected pattern, or do they pick up some defaults, If we do want a default start up, then a C to C octave of 16 steps in 4 4ās is probably as typical as one could wan, but thatās not to say other more inventive souls might appreciate considerably more latitude and screen estate.
The accuracy of the touch screen becomes an issue on musically wide and long pieces and because the interface places a note on touch contact and doesnāt leave the mode to note up, then allowing the note to be overwritten if dragged to a new note block would help tune you in, with the final note being allocated on touch up.
Itās easy to think for someone elseās coding, but this thread is an excellent place to observe the development of this device, and capture ideas about functionality . . . .
Iām not really participating to any of this (it really all is very new to me), but Iām trying to follow most of the topics hereā¦you guys are amazing!
What I just noticed, if I turn the back-encoder clockwise, the red selection rectangle goes up, I would expect the opposite.
Hmm⦠Clockwise to me increases value and the grid is organised with high notes at the top of the screen. I was thinking about that earlier and it is a matter of perception. Which way do you sit at the keyboard - facing the grid or with the grid behind you? I just checked a couple other step sequencers and they have the same orientation.
High notes at the top - we agree on that. Only from my point of view does a clockwise rotation always go down. Just as it is programmed in every other menu in zynthian.
Letās listen for further feedback / comment. If I donāt hear the contrary from anyone then I will change in next update.
Thank you for being open to proposels. So every one who is interested -please test this and write up your mind.
I concur.
Agreed
I agree with spurkopf
I completely agree.
Meanwhile, Iāve been trying it on a small touch screen⦠The Touchscreen is rather inaccurate in the corners . . .
I will try to see if we can
1/ Produce a webconf translation matrix that affects the display,
2/ Provide a set of values that can be tweaked to set this up. . . .
Not writing a note till touch up has completed but sounding notes detected would probably alleviate some of this and make it useable to a certain extent in the corners⦠. . .
Oh! this screenshot, reminds me that adjusting steps for the sequence produce screen refresh that arenāt synchronized at all with the encoders increments.
Maybe it could be a good idea to āfreezeā the screen during step adjustment (so long the encoder turn) and just show the changing number of steps in the top bar.
[edit] if possible of course
@le51 I have noticed that screen refresh is interlaced with encoder read / write which causes flicker whilst changing parameters with the encoder. Using the touchscreen or CUIA does not have this effect. I have done some investigation and it looks like this is due to the interrupts / thread events for zyncoder. I had come to a similar conclusion as you that pausing redraw until encoder has changed might help. I would prefer to redraw the screen as the parameter is changed otherwise the interface seems unresponsive but I will have a play to see what works.
okay.
As is, itās not really comfortable. Saying, you want 32 steps. You turn the encoder a lot, screen flick a lot and when it stops, youāve got 59 steps. Ok, letās turn the encoder again ⦠39 steps. Damn, turn and turn again and when screen stop flickering you are at 29 steps redamn.
Iām using a rpi 3B+, maybe itās more responsive with rpi4 ā¦
Btw, I will try touch screen to see how it goes
Not sure why, but i canāt seem to choose which midi channel i am sequencing? I can see it on the pad trigger page but not on sequencer⦠something i done wrong?
