ZynthianOS is the automated SD build system. The right place for that kind of requests is zynthian-sys ![]()
My Problem… I wasn’t up to date with title auto-scrolling…
2019-05-10 nightly: After some preliminary configuration and reboots I have several issues:
I changed the hostname back but still no joy. Was this build particularly broken?
Doh! I must have set hostname in the web-ui. That explains village fool 1.
I have configured for HDMI output and got it working so something wrong with my sainsmart18 config or maybe issue with stretch - TBC.
Doh! I misconfigured sainsmart18. That explains village fool 2.
I now have Aruk running - hoorah! (That was too painful!) I will report (actual) issues in github.
It would be advantageous to add sainsmart18 to the display configuration but I appreciate that this probably requires an overlay which I am finding challenging to source / create.
Thanks for reporting, @riban !
I find it a little bit disturbing, that jenkins shows the date of the start, but the image itself has the end date in the filename.
I don’t know, if everybody knows that. So you have to take the image + 1 day of the latest green build.
Yes. It’s disturbing. I will try to fix it …
Done!
BTW, i fixed by hand the filenames from the 4 latest images and tomorrow’s image (and following) should have the correct timestamp, same than Jenkins build.
