When I met Zynthian this was my goal: have a fully functional touch interface for a simplier build (avoiding enconders, pcb’s, etc). I just wanted my Zynthian to “enjoy myself” at home. I guess those who plan to use Zynthian on stage should feel more confortable with a pysical knob to play.
A few questions now…
Did “I2S SYN error!” message disappear? If not, do you hear something wrong (clicks, pops…)? what about latency?
How about sound quality? (compared to the iqaudio that you own)
Do you know if input and output gain can be controlled by sw instead of physical potentiometers? I gess the answer is yes.
Congratulation for this new interesting way of using Zynthian…i am also interesting at the possibility of using Zynthian for a guitar processor (my son plays guitar…) …
Q1: Yes the I2S SYNC is still there. But I do not notice any clicks or pops
Q2: Latency is to my ears very acceptable … I do admitedly notice a very small delay but for voice it is fine. Not sure about fast guitar picking… though…I might have time to plug my oscilloscope one day and get you a metrics.
Q3: Sound quality is good but if you do have the right levels in the alsamixer, But if you go louder you can definetely hear some white noise.
Q4: yes the alsamixer works fine and has a “MASTER” level as well as an "output mixer"
Q5: Also it seems that the audioinjector is much less sensitive to “low voltage” than the iqaudio.
As a mater of fact I can drive: raspberry pi3 + audio injector + 7’’ touchscreen + novation launchkey 25 + some basic speakers… all those powered from the the micro usb of the rasbperry pi with a single 2.4 Amp usb powersupply
Finally I enclosed the electronics tonight and I am pretty happy with the result. I’ll add some pics.
Hello I have taken an oscilloscope and traced input vs output signal using mod with a direct connection and a detune module.
I get a latency about 10ms if I go direct in mod and 20ms with the detune.
Obviously I removed the line in-line out bypass in the alsamixer otherwise there was no measurable delay…
It’s really an incredible toy and my kids are going crazy with the voice detune…
I guess the only thing which would be needed now is the ability to control from the launchpad a simple looper or a miniature sequencer like this one… http://filter24.org/seq24/about.html
But maybe I am dreaming or simply a bit spoiled by now…
Note that audioinjector uses some GPIO pins that are already used by Zynthian default configuration (the last statement is incorrect and amended in another comment below …). Althought you have no rotary encoders in your setup, Zynthian UI will try to read from it. I’ve fixed this in the last software version, so you should try it:
When you have correctly updated the UI software, you should edit the config file “zynthian_gui_config.py” and configure the GPIO layout as “dummies”:
hw_version="DUMMIES"
This will prevent the zyncoder library to try to configure and read the rotary encoders & switches.
Whew, you almost made me nervous. I have the audioinjector working just fine for output, but I’m still waiting for a cheap Chinese lcd to arrive. The kids don’t really appreciate when I’m using the TV as hdmi display. In the meantime I’m trying my luck with toner transfer for the pcb’s. I haven’t etched a board since 8th grade
Normally, this step is not needed and could break something, specially MIDI-IN, but if it worked, OK, it’s better to have an updated kernel and firmware
This is not needed, but. It’s intended for using an extra USB card, but i think it wouldn’t be needed never more.
Better to ignore. I will remove this function in the next release.
To be honest I am trying to replicate and take down notes but it doesn’t
work anymore I think my daq+ soundcard gets in the way now that I received
it… it’s a mess… lost a few hours already…
Hey all,
So i have a RapsberryPi official 7 inch display and an audioinjector. And I found that if I connect it to the SPI interface the audio injector stops working, but if I only connect the ribbon cable and the power it works. Strangely enough the touch screen also works.
