Hello!
I want to show you a Zythian with a larger Display
The Apple for scale
The configuration:
# 0.5. I like nano ^^
apt-get install nano
# 1. Update
cd /zynthian/zynthian-sys; git checkout .
cd /zynthian/zynthian-ui; git checkout .
cd /zynthian/zynthian-sys/scripts/
./update_zynthian.sh
./update_zynthian.sh #Yes twice - first run returns an error on a fresh installation
./update_zynthian_data.sh
./update_zynthian_recipes.sh
./update_zynthian_sys.sh
# 2. Edit fb1 to fb0 in all three files:
nano /etc/systemd/system/zynthian.service
nano /zynthian/zynthian-sys/sbin/splash- screen.sh
#Old # nano /zynthian/zynthian-ui/zynthian.sh
EDIT: In the latest Version FB0 has to be set in
nano /zynthian/zynthian-sys/scripts/zynthian_envars.sh
# 3. Also here:
nano /zynthian/zynthian-sys/etc/systemd/zynthian.service
# Find and modify the following line
Environment=FRAMEBUFFER=/dev/fb0
# 4. Edit boot/config.txt
nano /boot/config.txt
# Edit the following lines according to your screen
framebuffer_width=1024
framebuffer_height=600
# comment out both lines
#dtoverlay=pitft28-capacitive,rotate=90,speed=32000000,fps=20
#dtoverlay=pitft28-resistive,rotate=90,speed=32000000,fps=20
# Add those lines at the end of the file (I have a 7" Waveshare display - the values below should be adjusted according to your screen)
max_usb_current=1
hdmi_goup=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
# 5. Configure X11
cd /etc/X11/xorg.conf.d/
# remove all files except 99-pitft.conf
# edit the config
nano 99-pitft.conf
# the file should look like this
Section "Device"
Identifier "HDMI"
Driver "fbdev"
Option "fbdev" "/dev/fb0"
EndSection
# 6. In order to increase font size:
nano /zynthian/zynthian-ui/zynthian_gui_config.py
# Find and modify the following lines
topbar_height=48
font_topbar=(font_family,18)
font_listbox=(font_family,16)
font_ctrl_title_maxsize=18
