To add a pure data synth to Zynthian I’m assuming that I
Write the patch (include ctlin objects to speak to encoders) and put it in it’s own directory
Put a matching config.yml file in the same directory that maps ctlins to encoders and describes functionality, etc.
Place the directory with those two files and su patches in:
/zynthian/zynthian-data/presets/pure data/synths
(If the path is a little off it’s only because I’m typing it from memory. Also, I see that Csound is installed and ready to go … (?) (I can run a Csound file from the terminal, for example). But I don’t see a special layer for it as I do with Pure Data …
Am I missing steps with both Pure Data and Csound?
I haven’t uploaded any patches in Csound, but here’s how I add pure data patches. I’ll edit your steps to explain. I do steps 1 thru 4 on a PC.
1. Write the patch (include ctlin objects to speak to encoders) and put it in it's own directory. The
patch should be named with a unique name. In this example we'll call it wow.pd
2. Create a file and name it zynconfig.yml to map ctlins to encoders .and put it in the same directory.
Here's and example of a zynconf.yml file:
3. Use quotes, colons, underscores, spaces and commas just as shown in the example or it wont
load. Don't forget to include the first line showing the wow.pd name as shown in the example.
4. Select your wow.pd, any supporting files and subfolders and the zynconfig.yml file and use
them to create a zip file named wow.zip
5. Boot your zynthian. If you haven't updated your zynthian software since the Nov 17th update,
update it now or the following may not work.
6. Open the zynthian Webconf page on your PC.
7. Under Library select Presets & Soundfonts
8. Click on ZynAddSubFX - Synthesizer to expose the drop down selection menu
9. Scroll down and select PureData - Visual Programming
Select the bank you want your patch to go to. You can type in a New bank name and hit the plus
button if you don’t want to use an existing bank.
Click on the upload bar and then click on the click and choose button
Navigate to the wow.zip file, select it, then click on upload
Done!
I’ll give it a try later today. If successful I’ll see what’s possible with Csound (meaning can I figure it out!).
Thanks very much for taking the time to explain and document the steps with the video. MUCH appreciated! Maybe it’s an answer that should go right from here on discourse to a permanent home of the wiki?
Csound engine is alsmot ready, but i didn’t enable it yet because i wanted to do some extra test and include some decent instruments …
But if some of you have interest in it, i could enable the Csound engine on monday and hopefully you will contribute some nice instruments to include …
Here’s a zynthianized PD patch I’ve been playing with. Feel free to include it if you want to.
It is not for everyone as it is somewhat a toy. However, some may find ways to fit it in to a
musical composition.
I’ll include some sound samples to avoid the monocle . #1 and #2 were made using
the pd patch only, #3 was made with the pd patch in the background and a synth layer
playing on a separate midi channel.
Jut finished my travels … If you could enable Csound that would be great. I’d like to put some good patches together and also see if I can interface to it through PD. Maybe someone’s done that by now?
As another question, I’m wondering how far we are from SuperCollider? I wrote one of the first tutorials for SC3 so I have a bunch of stuff I could probably Zynthianise much more quickly than slowly.
All of that said, I know everything has to be step-by-step … Thanks very much
I’m having serious problems with the csound integration. It’s not very stable and i don’t like the csound way very much …
I’m seriously thinking about abandoning the csound zynthian engine and moving to SC, that seems more alive.
Anyway, i would upload a development branch, so you can enable the engine in your zynthian and try it a little bit, OK?
I thought I replied to your last message last night but I don’t see it on the board. In any case …
After more thought … if Csound isn’t stable within Zynthian maybe it’s not worth taking it past where it is now? Which best as I can tell is it’s not listed an an “engine” but it is working from an ssh login from another machine.
That being the case, maybe PD as a front-end for it is all that’s needed, assuming the PD objects that control Csound will run in Zynthian (so PD can call it)…
And SC is then the better bet as an engine? I will see in the next few days if I can get the PD-Cound objects to communicate.
If you make Csound available in whatever form will bang on that too
Hi, I am trying to learn how to zynthianize PD patches. I started with martin brinkmann’s wonderful “cells1” patch, which is 8 FM drums being controlled by a neural net.
I believe I followed all the instructions ronsum kindly provided above in this thread.
But the patch doesn’t work. Not only does it not play, the controllers I wrote into the zynconfig.yml file don’t appear. Whenever I load this patch, I see the controllers from whatever Previous pd patch I had loaded.
Could you set the scene with one or two pictures of what you did? Personally, I’ve done virtually nothing with PD and it’s always interesting to see the routes that are becoming well warn paths round here…?
Hi @exiannyc,
I am currently not able to access my zynthian, so I cannot check your patch. But I’ve checked your files and I think the problem with the controllers not working is the structure of your yaml file.
The structure of a yaml file is defined by intends and whitespaces. To add your “threshX” controller sections to the “midi_controllers” section you have to put a whitespace befere the “threshX” sections.
Please try it again with this file: zynconfig.yml (491 Bytes)
If there is still a problem I hopefully can try your patch on the weekend.
@wyleu Here are the instructions I’m following. I’ve taken the various layers of guidance above in this thread and zynthesized them all into the following. If we come up with corrections I’ll edit this.
Write the patch (include ctlin objects to speak to encoders) and put it in its own directory. The patch should be named with a unique name. In this example we’ll call it wow.pd
Create a file and name it zynconfig.yml to map ctlins to encoders and put it in the same directory.
Here’s an example of a zynconf.yml file:
Use quotes, colons, underscores, spaces and commas just as shown in the example or it won’t load. Don’t forget to include the first line showing the wow.pd name as shown in the example.
Select your wow.pd, any supporting files and subfolders and the zynconfig.yml file and use them to create a zip file named wow.zip
Boot your zynthian. If you haven’t updated your zynthian software since the Nov 17th update, update it now or the following may not work.
Select the bank you want your patch to go to. You can type in a New bank name and hit the plus button if you don’t want to use an existing bank.
As you see, the highlighted object “ctlin 65” is what i added, meaning “bring in the signal from the controller on MIDI channel 65 and put it here.” There is a ctlin inside each of the “pd cell” objects. The “threshold” parameter controls when each neuron in the net “fires.” Higher number, fires less often.
@weichselbaumj thank you very much for your edits and comments. I did upload your version to my zynthian. Unfortunately this did not make my patch work. Here’s the new (still not functioning) version. (It still has the same problem: when I open it, the controller layout from the previous PD controller layout is still in place on the screen of the Zynthian, although the top line of the Zynthian screen says it’s running this patch. No sound comes out.)
Anyway, as you can see I’m using the Purr Data environment (because it’s nicer looking - all those lovely gracefully curving cables), not basic Pure Data. And maybe that is the problem! I’ll try doing it in Pure Data later this evening and see if that helps.
Hi, I think I found another issue. Inside the “pd cell” the “ctlin” objct should be directly connected to the number object. In my understanding the way it was originally, a message from “ctlin” just triggered the message object with the default value.
But there seems to be another problem which I was not able to identify. Most of the time when loading the patch, no “ctlin” messages are received. Then after some reloads the patch and all controls work as expected.
Can you reproduce this behavior on your zynthian?
Here is the modified, sometimes working patch: zyncells1mb.zip (5.2 KB)
Zynthian PureData doesn’t seem to like certain filenames. I don’t know why, but I have come across this several times before. Perhaps someone else can shed some light on this. In this case, I logged into my zynthian using Putty with X11 forwarding to allow me to display the PD gui when the patch was launched. The PD window showed the file zyncells1mb: can’t open
So using my windows pc, I changed the name of the pd file to Zyncells1.pd and the first line of the YAML file to main_file: “Zyncells1.pd” and used the two files to create a zip named Zyncells1.zip. I then uploaded the zip to the zynthian, rebooted and loaded the newly named pd patch. After a few seconds it started playing.
I would suggest @exiannyc add an object to control the volume using midi cc7. In most zynthian pd patches the volume control is the first control on the first page of controllers. I also notice thresh2 can give unpleasant results when adjusted to zero depending on settings of the other controllers. The patch could be revised to disallow thresh2 going to zero.
The revised and renamed patch still doesn’t work on my Zynthian, but I’ll keep tinkering, with this and other patches. (OuterSpaceSynth and Grids sound great, though!)
@ronsum, your feedback on the patch is very welcome. My current Pure Data knowledge is pretty limited, but it’s great to have a push to learn more.
This patch works for me if I load it twice! (add pure data layer --> load the patch --> delete the layer --> add pure data layer --> load the patch)
Midi control messages are not received after first load after a fresh restart of zynthian. If I find some time I will have a closer look to this.
