Apr 05 04:54:03 zynthian startx[5236]: INFO:root:Bold Switch 4
Apr 05 04:54:03 zynthian startx[5236]: INFO:root:All Notes Off!
Apr 05 04:54:03 zynthian startx[5236]: INFO:root:All Sounds Off!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 0!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 1!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 2!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 3!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 4!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 5!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 6!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 7!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 8!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 9!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 10!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 11!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 12!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 13!
Apr 05 04:54:04 zynthian startx[5236]: INFO:root:Raw All Notes Off for channel 14!
Apr 05 04:54:04 zynthian startx[5236]: ./zynthian.sh: line 127: 7057 Segmentation fault ./zynthian_gui.py
Apr 05 04:54:04 zynthian startx[5236]: PNG file: /zynthian/config/img/zynthian_logo_error_ip.png - Application must supply a known background gamma
Apr 05 04:54:04 zynthian startx[5236]: /zynthian/config/img/zynthian_logo_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4545
Apr 05 04:54:04 zynthian startx[5236]: Zooming image by 133%…done
Apr 05 04:54:04 zynthian startx[5236]: Merging…done
Apr 05 04:54:04 zynthian startx[5236]: Building XImage…done
I disabled all MIDI out ports before I made the test. Anyway, if MIDI out is not disabled, the result is the same but the crash was at channel 7, so I don’t thing it has something to do with a paticular channel.
Sorry, but as a musician I’m in the learning stage and I don’t think, that you like to hear my voice . My expierence in programming is also not so high. I normally have to program on windows. But I plan to install a development environment.
Don’t worry, it’s really all a community building effort and as someone who is enough of a musician to know how good real dedicated musicians are, it need to be nothing more than one note from a patch that you like, or perhaps don’t like.
At the end of the day the zynth is a musical instrument and it deserves to have it’s voice heard by fellow like minded souls . . . .(*)
(*) soft sentimental version aimed at tugging the heart strings…
Very good idea to use a DIN-5 connector for it!! Congratulations!!
Please, could you give some details about the configuration (webconf) and add some photo of the wiring, etc.? I’m sure that other @zynthianers would find it very useful !!
Hi Jofemodo,
I read your thread from dez 1st 2018
how to i stall the sustain pedal and the panic button.
I do not know how to solder a “5pin connector” at the allInOne board.
In my Zynthian I see the flat cable and the connector is as long as there are pins.
Which Zynthian version do you have? The original all-in-one board did not have the 5 pin breakout for the extra switches. These were added in the updated all-in-one board. Extra switches can, however, still be added to the original all-in-one board by soldering wires directly to the pins on the MCP chip. This is what I did. I’ll post some photos of this when I get home tonight.
The first one is a raspi 3 and i want to build it in my livetime projekt.
This is a Böhm CNTKeybed in a DX7-case with a Böhm 12/24 expander. When this Zynthian has a sustain-pedal, I have a small setup without missing sounds.
The second one is a raspi 4 with a 5"hdmi monitor and a behringer UCA222 2x2 Interface. without knobs and faders. I try to play it without an own ui, just using the control channel and notes on the keyboard.
I don’t know how to add fotos, excuse Problem solved, thanx!
Sidenote/question: how faulttolerant is the os for just yanking the poweradapter out (as turning off zynthian)? Preferably a switch/button to call for shutdown-command would be nice. Maybe its already been implemented, in that case sorry for my ignorance
