webui
changed audio to usb audio
wiring to emulator also custom 0,0,0,0 and also tryied almost every wiring type there is
I have nothing else connected to the gpio other then the lcd
I don’t have hardware wiring hense I tryied everything, and nothing works
I get the white zynthium start screen and red writing ERROR
I think ive tried enough to call this one a day now
think I’m going to try the moonbox there is
unless someone can pull out the box a instructions guide to make my system work
raspberry 3
usb audio
or hifiberry dac
ive got both these
waveshare 3.2b clone
hdmi monitor
does touch screen work? on the software for my waveshare 3.2b
no wiring yet, I’m yet to get some caps to to make this work, I have encoders and veroboard pcbs
When you hook up a HDMI screen, we can’t help fix the problem.
Configure the zynthian that is uses a waveshare, connect it and show us the logtrace.
My waveshare32 is working like it should be.
Sounds working
Raspberry 3
Hifiberry dac+
Hdmi monitor
Mouse input
Midi from mpc to zynthium
It’s working
I think my waveshare clone is using some pins that the hifiberry uses so I. My just sell the lcd and get a small Hdmi monitor and use mouse to manoeuvre around the gui
Good luck with the Orange Pi … you will have to re-build the SD image from scratch and adapt a lot of things.
The setup script from the zynthian-sys repository should be a good starting point:
Of course, i’m SUPER-INTERESTED in seen Zynthian working on Orange Pi!!!
