I’m currently building my own version of zynthian (geared towards playing live music) and I’m planning to 3D print the first few design iterations. Are there any 3d Designs for a case with a raspberry 4 and a hifiberry (DAC + ADC) already available? I’m using solidworks and inventor but a step file is fine too.
Sorry, i don’t have 3D files that you can use for 3D printing. Perhaps i could export a STEP for the aluminum case, but the manufacturing process we use is “laser cut + sheet metal bending”, that is very different to 3D printing.
@freeKey mentioned how the 3D case he has isn’t really up to the task due to its manufacture following the aluminium case design. Additive fabrication is very different to subtractive fabrication so you will need to take care to avoid the issue he experienced.
Thanks for all the replies, I will try with the 3d file mentioned by @ronsum, of course the official files would be helpful too, I’ll just wait a bit
I’ll make sure its 3D printable and check out @freeKey issue, I’ll post the results once I’m happy with it. It will most likely have some changes extra switches etc.
I never posted this anywhere, just told about it shortly in one of the Zynth Club gatherings. So:
I didn’t print it myself but bought mine from hekokkong. It is this one: V3 Build Success
probably following this discussion Is there a 3d printable case for the v3 kit?
Well, it basically works, but isn’t particularly stable or precise. I guess the main problem is the shape of the two parts since the U-shape is hard to print well. Just my 2ct.
For my own case (pun intended), it was clear from the beginning that this is just a temporary solution as a start to play around with before I make my own, more stable case.
I’ve recently designed a case in Onshape (I think you need an account to view; you can mix/edit and export STL from there), which was also featured in the Success cases thread, see over there for a bit more info and picture.
Sorry to revive this old post.
Would it be possible to have the step files for the previous official cases (v4 in particular)?
I checked in the repo but in the Aluminum-PiScreen-v2.*/ZynScreen-v4 folders I couldn’t find only the STEP file for the Aluminum-PiScreen-v2.2 base but no top.
My goal would be mostly an exploratory attempt of mirroring the USB and ethernet holes of the V4 case to fit a Raspberry Pi5, and learn some CAD in the process. In case i’m successful and there is interest, I will of course add the updated file in the repository.
