And now you can. ![]()
Actually you already have, so donāt unless youād like to.
The responsible minion has been chucked from the castle battlements as punishment. . . .
Itās the only way we get things done round here.
Iāll still do it, I have an old MIDI keyboard Roland PSR-30, I want to embed on it Zynthian.
I like the sounds, there are a lot of sounds from the 80s.
Looks great! Iām planning to add one into an old 49-key controller I have. Do you know, can you run Zynthian āblindā (albeit with less usability) without using an LCD screen? And also, is it possible to remap the functions that the 4 hardware knobs around the screen would control to other knobs instead? So for example, if I didnāt add any extra knobs to my MIDI keyboard I could just use some of the knobs it already has to perform the functions that those 4 knobs around the screen would do?
The problem with midi controllers mapped to the encoders is that as they are encoders not pots itās not really possible to map the concept if a midi controller is set to value 3 or 4 how does this then map to a list function where you might want to scroll 15 or so entries down in a zynth list⦠The other problem is how do you do the encoder of the encoder push?
You can work a zynth without a screen but you really need the visual feedback to tell you where you are in the interfaceā¦
Nice!
But what are you doing with those extra knobs?
Main Volume and Headphones Volumeā¦
What kind of amplifier are you using for headphones?
MAX97220 headampā¦
Sound, Roma, sound⦠We all wanna hear the soundā¦
I know that strict monocle
Never a truer word was posted.
Those are some nicely laid out snapshots there. . . .
this is sets for liveā¦
my GIG library and engines zyntians⦠Linuxsampler, Dexed, MDA E-Piano, ZynAddSubFXā¦
I disagree.
He is using duplicate numbers. Thatās not how it is supposed to be.
You are not able to control it via maybe channel like that
Oh, the horror!!! ![]()
