Oh, I have one since summer… I have to build the case.
It’s a nicesynth but has some problems with higher frequencies. That’s a known problem with the Teensy-Audio-Library which is using non-bandlimited waveforms. A user made bandlimited ones for some waveforms (and they are included) but others seem to create artefacts in higher frequenies. But this is not only a TSynth problem!
Nevertheless it is a nice synth with an analog touch and will be included in my upcoming setup.
I made one with a Teensy-3.6. If someone wants to build one, try to use a Teensy-4.0!
Regards, Holger
To give it an even more analogue feel… add a low pass filter to fix those high frequency artefacts!!!
I have tried this in several variants but it was not satifying…
I totally ate a mince pie. Still can’t get the minisynth kernel to boot though.
edit: needed an older version of the toolchain (9.2).
Noisy reverb and some detune in the second half of the clip elevates it just above a casiotone now.
Can you share the image at all?
Yes.kernel.img (495.5 KB)
Zynth Club on Blue Monday?
anyone…?
Is that a new order for the 18th Jan, then? At 19:00 zmt?
Okay, let’s reconvene the high order of the Zynthaniers. Meet at the lodge at 19:00 UZT on Blue Monday 18th January 2021. Last one in brings the leftover toffees from their Christmas chocolate selection box.
If you need directions send me a direct message.
How many Blue Monday’s are we doing this month …?
Just the one.
I refer the honourable gentleman to this …
Which was consisely responded to with clarification of when Blue Monday 2021 will occur.
:tongue:
I’ll be there :wink:
The Countdown is running
Please, can I join?
Sure. I have sent you details.
