Wow, this guy is really something, looks like he etched the boards himself.
Can we get a hold of that guy? If you’re around, manifest yourself!
Hi all,
First congratulations for this very nice project.
I was looking for a way to expand my electronic piano and Zynthian fits perfectly with my needs.
Here is a picture of my current setup.
Next steps:
-Connect the headphone to the DAC instead of the RPi jack;
-Find one or two very small amplified monitor speakers (I wanted to connect the Zynthian to the input line of the piano to use it as a speaker but I can’t find a way to disable the sound from the keyboard). Any advices for monitor speakers ?
-Connect the Volca.
Have a nice day
Adrien
Hi Adrien,
Most Roland digital pianos allow you to turn off the internal sound. What model do you have?
Hi and many thanks for your reply. HP603A.
It looks like you can turn off Local Control by going to the Function Mode. Here’s a link to the manual: HP603A Manual
Page 18 describes how to get to the Function Mode and how to navigate and change parameters. Page 20 describes what Local Control is. I think once Local Control is set to off, the keyboard will not trigger the internal Roland sounds but will still transmit midi to trigger the Zynthian. You’ll have to try it to find out for sure.
If you send the Zynthian audio out to the Roland audio in, you may need to adjust the Input Volume of the Roland. The Input Volume is also set using the Function Mode.
Some keyboards retain option settings when you power down. If your Roland retains the settings, you might want to turn Local Control back on before you power off. This way your piano will be ready to play it’s own internal sounds the next time you turn it on.
Here’s my attempt at a case.
Good job (Way better than my Chinese junction box) it does resemble a monitor/TV.
The Zynthian cartoon network logo?
Thanks… and yep I was going for something like that
Greetings to all! I have a question for you, will Rock Pi 4 be compatible with Raspberry Pi4 for building zynthian ?
Hi @rozhok ,
you will have to build the Zynthian software by your own using as starting point the minimal Armbian debian buster image.
(You have to scroll down at the bittom of the page ti find the download link).
Then you have to follow all the steps as mentioned in the setup script (and all the others scripts that are called by the setup script).
Some adjustments are needed (remove some specific raspberry pi stuff like firmwares) as in the envars file where compilation flags have to been changed.
I’ve managed to achieve the process on NanoPi K1 (Allwinner H5 soc with 2Gb ram +32Gb emmc) a couple of years ago. It was a really long and hard way mostly because of the lack of computing power.
RockPi 4 is much more powerfull and is well supported by Armbian I guess.
Suggestion : in the setup script you’ll see a bunch of
apt install …
Make this in first.
Then do all the software download/compilation process (more or less the receipes that are here).
Make a disk image of your drive !
Then lastly apply all the patches that alter system configuration and start up scripts.
Thanks a lot!
Hello! Do not configure touchscreen 5inch hdmi-gpio
https://aliexpress.ru/item/32786838470.html
Here are some pictures, I took advantage of the keys of a prokeys 88 with a burnt motherboard. I’m reading the keys, knobs and faders with a mega arduino, I put a distance sensor too. I really enjoyed the platform, congratulations it’s perfect!
If anyone wants to watch it, here’s a video, a loop of guitar and piano and voice, all directly on zynthian take a look at the link:
Nice build, congratulations
How does the Arduino communicate with Zynthian ? Midi, Osc, i2c, … ?
The Arduino mega that reads keys, knobs and faders communicates via USB as a native Midi interface. The Arduino promicro I used to control the zynthian interface communicates via i2c.
Zynthian+SamplerBox
Congratulations @rozhok
