Currently you can buy Zynthian Kits in the Zynthian Shop:
This post is kept by historic reasons only and you shouldn’t use it as a reference for buying zynthian kits nevermore.
Hi @Zynthianers!
This is the list of Zynthian Kits that i’ve prepared for those who don’t feel the desire of building his Zynthian Box completely from scratch ![]()
The original post is from September 2016, but i update regularly the list of kits, prices and availabilities.
Last update: 2017-10-09
| Product | Price | Status |
| Zynthian Controller Single PCB | 3€ | Available |
| Zynthian 2in1 PCB | 6€ | Available |
| Zynthian All-in-One PCB | 10€ | Available |
| Zynthian Basic Kit | 80€ | Available |
| Zynthian Basic Kit pre-built | 150€ | Available |
| Steel Case Kit "Black Label" | 120€ | Sold Out! |
| Aluminum Case Kit | 75€ | Available |
| Wooden Case Kit | 35€ | Available |
| Zynthian Basic Kit + Aluminum Case Kit | 150€ | Available |
| Zynthian Basic Kit + Wooden Case Kit | 110€ | Available |
| Zynthian Bundle All-but-the-Case Kit | 190€ | Available |
| Zynthian Bundle All Alu-case Kit | 260€ | Available |
| Zynthian Bundle All Alu-case Kit pre-built | 350€ | Available |
| Zynthian Bundle All Wooden-case Kit | 220€ | Available |
| Zynthian Bundle All Wooden-case Kit pre-built | 310€ | Available |
| Zynthian Bundle All Steel-case Kit | 300€ | Sold Out! |
| Zynthian Bundle All Steel-case Kit pre-built | 390€ | Sold Out! |
Shipping is not included in the prices above. It depends of total weight and shipping address.
People interested in getting one of this kits can reply on this post or contact me directly by private message. Click my user’s avatar!
Note: From October 2016, the new controller modules replace the old ones. I’ve split the controller module in 2 single units to improve modularity and for an easier replacement.
Note 2017-10-09: The new Aluminum Cases are ready! This cases are slighty bigger, designed for the OzzMaker PiScreen-2 display (3.5"), that replaces the smaller PiTFT 2.8" display. Also have MIDI-IN and MIDI-OUT connectors.
The Zynthian Basic Kit includes:
- 4 x Zynthian Controller Single Modules
- 1 x Zynthian All-In-One Module
- 1 x Main Ribbon Bus Cable
- 1 x Wiring Kit (JST connectors)
- 40 pin + 3 pin connectors for the HifiBerry
The Zynthian Basic Kit pre-built has all the parts soldered on the PCBs, like this:
Note: This photo shows the Kit v1 pre-built
Note: You have to solder the HifiBerry connectors yet!
The Aluminum Case Kit includes:
- Aluminum Case
- 4 x “Moog Style” Knobs
- 2 x Jack Mono Connectors (audio line-out)
- 2x MIDI Connector (a decent one ;-))
- 4 x Rubber bumps
- Spacers, bolts and nuts
The Wooden Case Kit is the same, but the case is made of “DMF 3mm”, cutted with lasser:
The Steel Case Kit is the same, but the case is made of hard Steel. Heavy and expensive, i know, but absolutely solid and unbreakable. This case was used for the first prototypes, those with black-red knobs that you can see in the website. This is the BEST official case that Zynthian will have ever, and the 2 remaining units probably are the last ones you can get. It’s “black label”, no serigraphy!
Finally, i have prepared the Bundle All Kit that includes everything you need to build a zynthian box:
- Zynthian Basic Kit, with PCBs, electronic parts, wiring and knobs
- Aluminum Case Kit, with nuts, bolts and case connectors
- RBPi 3
- HifiBerry DAC+
- TouchScreen Clonic PiTFT (2.8") or Original OzzMaker PiScreen 2 (3.5")
Of course, if you don’t need some part because you already have it, i’ve no problem with “customizing” the kit to fit your needs.
There is a pre-built version too, so you don’t need to solder anything if you don’t want, only plug the wires and screw the bolts ![]()
Note: This photo shows the steel-case “black label” with Kit v1
This is the “official” reference info for building a Zynthian Box using the kits offered here:
These are older references that you could find useful too:
And for the braves who likes the hard way, here is all the info you need for building a zynthian box from from scratch:
- GitHub - zynthian/zynthian-hw: Zynthian hardware stuff: PCBs, schemes, parts specifications, pin assignment, ...
- GitHub - zynthian/zynthian-case: Zynthian case building stuff: plots, schemes, photos, renders, STL/CNC files, ...
Best Regards!
